2 Subs?
I just grabbed the PSW505 from newegg over the weekend for 200. As i am new in HT,was just wondering if i wanted to add another sub to my setup down the road should I stay with Polk? Can you mix and match subs?
Home Theater Setup
Receiver: Yamaha RXV 665
Fronts: Polk Audio Monitor 60
Center: Polk Audio CS1
Rear: Polk Audio TSI 300
Sub: Polk Audio PSW 505
BluRay: PS3 Slim
Xbox 360
Display: Insignia 1080p 50" Plasma
BluRay: PS3 Slim
Xbox 360
Post edited by AR15223 on
Not a good idea to mix & match subs. Best to go with 2 that are the same.
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Agreed don't mix. I have two PSW505s at the current price might as well buy another. Hard to find something at $400 to beat the combo. Some $600 subs would probably beat the pair out though.System:
Samsung LN46C630
Receiver: Yamaha RX-V1
DVD/Blu: Denon 2910/Playstation 3
Front mains: RT16
Front presence: F/X 500i
Center: CS400
Rear surrounds: RT1000p
Rear center: RT7
Subwoofer: PSW505 X 2
Marantz 2252B
Technics SL-Q2 turntable
Kef Q50 -
In a pure 2 ch system with a dedicated sub for each channel you probably don't want to use two different subs. In a home theater it's really not a problem. It will take some work to get the phase settings right so you aren't cancelling out bass, and it will take some work to get them dialed in. I have always had different subs in the front and rear of my HT and it works just fine.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I concur with 2 different subs is doable for theater use (not for stereo as mentioned above for obvious reasons)
some say stacked is right, some say opposite corners. who is right? both, and no one. the real answer is it depends on the room.
2 different subs is great if you got the 2 for a great price or used and it is what you have to work with, though should not be a goal. Finding what works best with 2 subs can be a major pain in the nuts. I say the best starting point is stacked, then play from there.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
