Cd cleaning
ratster
ratster Posts: 324
edited November 2010 in DIY, Mods & Tweaks
After a lot of years of spilled coffee,cokes and cigarette ashes a lot of my Cd's are in need of some serious cleaning before I use them in my new cdp :eek:
Any suggestions on the best product(s) to use,or good home brews?
Main
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Clear Day dbl.shotgun
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
Clear day dbl shotgun
    treitz3 Posts: 20,366
    A Stoner product called Invisible Glass would remove any and all grime and oils.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    For many years I've used Rain-X on CDs and DVDs. Not only can it clean them I think it can improve the sound when played with lesser expensive CD players that use plastic lenses and less evolved error correction systems.
    Cheers, Ken
  • AudioGenics
    AudioGenics Posts: 2,567
    ,,, Rain-X on CDs and DVDs. ....
    Wow.
    any special applicator ?
    do you use it with a microfiber cloth to apply and remove or a kim wipe ?
    what amount ... a few drops or so ?
  • [Deleted User]
    Hello,
    I use 100% cotton balls, a few drops around the surface. Then wipe around the disc and follow up with another cotton ball to polish the surface. If you look at your reflection in the disc before and after it should look more reflective.
    Enjoy, Ken
    Mr. Swauger, I wasn't kidding....are you?
    I have this strange feeling that something just ain't right with that....
