Any computer geeks here? Question on a TB drive
starkiller
starkiller Posts: 2,723
edited November 2010 in The Clubhouse
Am looking at a 1 or 2 TB drive and would like to know how many hours of uncompressed cd quality songs they can hold. I can get the NUMBER of songs they can hold but that does not take into account songs that last the entire side of a disc or songs that lat 10minutes etc.....
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
  • nguyendot
    nguyendot Posts: 3,594
    Flac?
    Main Surround -
  • starkiller
    Nope, straight from cd player to hard drive....
  • danz1906
    danz1906 Posts: 5,144
    I have an 500gb drive with 143gig of WAV audio file 1411kbps in iTunes.
    It say 18.7 days of Music, so about 450hrs of music.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • wayne3burk
    wayne3burk Posts: 939
    That would be a .wav file....
    just figure 650 megabytes per CD....
    1 gigabyte per two CDs
    1000 gigabytes per 1 terrabyte
    2000 CDs
    easy
    -- wayne --
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • wayne3burk
    p.s. -- I just bought a 2 terabyte drive from target for myself for christmas.... and i was asking myself the same question.
    but i'll probably go with flac files as they are lossless compression and you get about 50% reduction in file size from what i can tell - with no loss in SQ.
    good luck.
    wayne
  • falconcry72
    falconcry72 Posts: 3,580
    An uncompressed WAV file at 1411kbs is about 10MB for 1 minute of 2-channel audio.
    You're lookin' at about 1600 hours of music on a 1TB drive, 3200 hours on a 2TB drive.
    I've got 6TB of music space right now (3TB internal backed up on 3TB external); it's 99% FLAC and SHN.
  • acs_rpeters@msn
    acs_rpeters@msn Posts: 32
    I see about 120 KB per sec of music uncompressed. 1TB = 1,099,511,628 kb so about 2545 hours of music
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    Hard drives are so low in price, you may as well go with the larger drive.. even if you don't think you will use it.
  • falconcry72
    hmm. I got more like 166KB per second of music:confused:, which is more like 1850 hours not the 1600 I said before.
  • starkiller
    Actually i am thinking about buying two of the 2tb western digitals...missed them on sale at staples for $69ea :eek: but can still find them for around $90 ea...
  • cokewithvanilla
    starkiller wrote: »
    you have a lot of music. that's a good price.. 7200 rpm??? they have a seagate for $69 right now at newegg... only 5900 rpm though...still fine for storage.
  • starkiller
    Yep, about 2,000 cd's and about 700 albums I will be transferring also...
  • acs_rpeters@msn
    If you ever plan on transferring between the two or adding movies I would looks fo one with an eSATA connection as it will transfer 100 times faster.
  • ryanjoachim
    ryanjoachim Posts: 2,046
    starkiller wrote: »
    You can get 2TB drives from Newegg for $69 right now.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • steveinaz
    steveinaz Posts: 19,545
    A single song of "average" length is generally about 24-35 Mbytes in *.wav format.
  • nguyendot
    Time to invest in a powervault or equalogic box ;)
    Main Surround -
    heiney9 Posts: 25,447
    wayne3burk wrote: »
    good luck.
    wayne
    The nice thing about FLAC is you tag all your music. WAV files can't be tagged. You can rename the file in the folder on your HD, but once you transfer that anywhere else there is no tag. If you ever plan on using any type of music server or other player like foobar or media monkey or even iTunes there won't be any identifying info embedded in the file. That will be a REAL PITA later to add tags to all your music.
    WAV is the worst choice if you plan on managing your music at all. Go FLAC and get the tags as you rip your music, then your set for whatever direction you choose in the future.
    Let me be more concise about metadata tags for WAV files. It can be done, but it's not that easy and I don't believe it's universal.
    http://www.hydrogenaudio.org/forums/index.php?showtopic=74252
    read post #8
    To the OP, why WAV files and not FLAC? You are going to create a headache going with WAV
  • starkiller
    Could not find the deal at Newegg....
  • mmadden28
    mmadden28 Posts: 4,283
    wayne3burk wrote: »
    2000 CDs
    easy
    -- wayne --
    +1
    Personally I'd go FLAC though and save more space as well as the tagging capabilities as H9 mentioned. FLAC can be converted back to WAV if you ever wanted to (it's bit for bit identical to the original wav).
    Whatever you decide, without a doubt double what you get--it is an absolute must to backup the media. You don't want to spend 100s-1000s of hours ripping CDs, to a drive that might fail.
    Either get a mirrored external drive(has two physical drives mirrored to each other in one external box), or manually (even if scheduled) ensure a backup to a second physical drive.
    You could also do internal drives the same way. A lot of newer motherboards have RAID support anymore, and this sometimes includes RAID with external drives.
    I'd rather do more smaller drives than a single larger drive. Don't put all your eggs into one basket as the saying goes. :wink:
    For external, +1 on eSATA if you can swing it (if your system supports it or you get an add in card), or even USB 3.0. USB 2.0 is about 480Mb/s, where eSATA is about 3Gb/s for transfer rates. It's really a factor when doing mass transfers such as complete backups, etc., not so much a factor when just ripping one at a time or streaming from it.
    ____________________
    Pool: Atrium 60's/45's
    starkiller wrote: »
    I bought a 2TB for $89. It's on the main page under Black Monday, page 2 or 3.
  • bobman1235
    bobman1235 Posts: 10,822
    2TB $70 : http://www.newegg.com/Product/Product.aspx?Item=N82E16822148413
    Right on the main deals page.
    bobman1235 wrote: »
    I assumed external, yes internal drive are a bit cheaper.
  • ryanjoachim
    By the way...1.5TB is now $60 on Newegg (internal)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148337
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • ryanjoachim
    Not for 6x the amount of money compared to a 1.5TB drive. Jeez.
    I do need the space though...
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
