2003 Chevy S-10 dash speakers
acs_rpeters@msn
acs_rpeters@msn Posts: 32
edited December 2010 in Car Audio & Electronics
I have a 2003 Chevy S-10 Which im looking to replace speakers in. It has 6 ½ door and 4x6 dash. I have looked on Cruthfield and it lists no dash speakers that will fit. I wondering if anyone has replaced these and if there is a great deal of modification to get them installed. Im currently looking at the Polk DB461P as the replacements
Post edited by acs_rpeters@msn on
  • Systems
    Systems Posts: 14,872
    edited November 2010
    I have done it in a '98 S10.
    I used Boston 4x6's and there were no problems that I can remember.
    I used a ratchet with phillips insert because you cannot get a screwdriver in there because of the windshield.
    I had to use some spacers on the 6 1/2" door speakers because the speakers (Phoenix Gold Comp set) depth was to great for the door.
    Neither is a hard install.
    Testing
    Testing
    Testing
  • acs_rpeters@msn
    Thanks, I will give it a shot here soon and see how it goes :D
  • LONG TIME BUYER
    LONG TIME BUYER Posts: 112
    thanks, i will give it a shot here soon and see how it goes :d
    its no problem.i have a 2003 gmc s-15,its no different. If you put a 4x6 with a bigger magnet just use a heat gun to push down your ac ducts.
