Ionic Breeze Owners
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited November 2010 in The Clubhouse
So I just bought a use Ionic Breeze and got it in the mail today. Plugged it in and had weird noises so I cleaned the blades but still had noise.
I than read this and decided to try it.
http://www.fixya.com/support/t2813800-ionic_breeze_gp_s1830_makes_sizzeling
I did not scrape the cones but just wiped them down.
Most of the noise is gone but the sound I hear now is like a slow leak out of a air hose. Is this a normal operating noise?
Also the smell coming out does not smell like a rain storm I can not really describe the smell. Anyone know if this is normal?
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • AudioGenics
    AudioGenics Posts: 2,567
    We have several Ionics bought new since my son is allergic to various things.
    no issues and nothing like what you are describing.
  • bigaudiofanatic
    So what does it sound like when it is on? Can you hear air coming through?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • AudioGenics
    There is a very slight hum
    but it is not noticeable across the room.
    We plan on getting a whole house air filtration unit
    when the budget gets there
  • bigaudiofanatic
    Ah, it seems to be getting more silent as time goes on. I also think that it just needed to be cleaned and gave some time to work in the room a bit. Will see later tonight.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • AudioGenics
    by the way
    if you have an air compressor ( some vacuum cleaners you can use the exhaust )
    using some pressurized air to "blow out" some of the dust is helpful.
    and don't use any solvents at all.
    good luck.
  • bigaudiofanatic
    Seems that the cleaning and waiting worked. Can not even hear it really and the slight hum is what I hear now. Smells better now to.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    tonyb Posts: 33,069
    The fins have to be totally dry too before turning on after cleaning. I have one and even though it's silent, it's not very good in a mid to large room. Mainly because it's poor at moving air. Sometimes it makes noise when it's dirty,and sometimes it makes noise when it's not completely dry.
  • bigaudiofanatic
    Ya I got it to help with dust from getting on the ML's and to help make the room smell better which is a plus.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • nguyendot
    nguyendot Posts: 3,594
    I've got two ionic breeze towers and a prozone....
    The ionic breeze towers make that hissing sound sometimes, it goes away if you clean it and wait. Make sure the wires are absolutely clean and the blades are totally dry.
    The prozone box...is a godsend. Kills odors faster than anything!
    Main Surround -
