Cs400- I'm stumped guys!! Who can help?
angelsfann02
angelsfann02 Posts: 589
edited November 2010 in Speakers
Trying to make long story short...one driver was not working. Pulled and tested all drivers and tweeter. Connected each directly to a receiver at low volume. All 3 speakers play fine. Ordered new crossover reconnected everything, same bad result. One driver still playing. I swapped driver and still no sound. Could I have received a bad crossover from polk? How does one check everything (x-over, speakers etc) using a multimeter? Please be specific. Thanks and happy thanksgiving!
LIVING ROOM:
Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
Post edited by angelsfann02 on
  • AudioGenics
    AudioGenics Posts: 2,567
    happy thanksgiving.
    with the multimeter you could verify that all connections
    are good ie. not open or shorted
    perhaps a bad internal wire or connector ?
    i would be surprise if the Xover is bad but
    you could check each component is good
    is there any protection fuses or protective device /breaker in a 400 ?
    I'm not familiar enough with the model
    a schematic to aid tracing would be very helpful in diagnostics.
    if this is new to you keep a notepad of what you checked and done
    and keep cool....
    also see http://www.polkaudio.com/forums/showthread.php?t=108221
  • angelsfann02
    Here's to my homer simpson moment. I had reinstalled the old crossover! Doh! Thanks guys. Moderator please close thread.
    LIVING ROOM:
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Now that was Funny!
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
