wall mount for FXi A6
Stirling
Hi
Was wondering what is a reasonably price wall mount for this speaker. Are there any that doesn't require you too drill into the enclosure and if so will that affect sound?
They can be simply mounted flush against the wall with 2 screws( no mounts required) but I assume slightly away from the wall would be better..sound wise correct?
thanks
thanks
If you wallmount them, they don't have to be flush agains the wall, you can live the screws a little off the wall, plus the look better.Samsung HP-T4254.
Denon AVR-3311ci, Emotiva XPA-3.
Polk Audio Monitor 70's and 30's, CS2, FXi-A6.
Sony PS3, BDP-S470,Toshiba HD-A2.
AV123 MFW-15 "The Beast".
Logitech Harmony 880, APC AV H10.
