Help Picking new fronts
AR15223
AR15223 Posts: 13
edited November 2010 in Speakers
Hello all, Happy Thanksgiving. I am looking to get closer to complete my setup. I currently have
Yamaha RXV665
Polk Audio CS2
Polk Audio Tsi300(rears)
Now i am in the market for a sub or for two front. Just cannot decide which to buy first. Thinking of either the PSW505 from Polk, or i may shop around a little and look at other brands. I am also looking at the monitor 60 series II from Polk Audio, as they are on sale right now.
So my main question is how will the Tsi300 sound with the monitor 60s???
Home Theater Setup
Receiver: Yamaha RXV 665
Fronts: Polk Audio Monitor 60
Center: Polk Audio CS1
Rear: Polk Audio TSI 300
Sub: Polk Audio PSW 505
BluRay: PS3 Slim
Xbox 360
Display: Insignia 1080p 50" Plasma
  • mdaudioguy
    mdaudioguy Posts: 5,164
    It won't be a problem at all. That would be a good setup. If you can swing it, go for it! Enjoy. :smile:
  • Vette C6.r
    Vette C6.r Posts: 1,560
    delete
  • raffi
    raffi Posts: 114
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290130
    Don't know how that combo will sound together but if you're going to pull the trigger on that sub, newegg has it right now for $199.99 shipped...lowest price I've seen thus far, it's a good sub for the $.
    2 channel rig: MMF 2.2 turntable, Adcom GFP-715, Adcom GFA-555, Adcom ACE-515, Carver M-1.0t, Denon 5900 CD/SACD, SDA-SRS 2.3s (Zardoss modded), AQ Diamondback & King Cobra IC's and AQ Type 4 speaker cables
    HT rig: Panny 50" G20 plasma, Directv DVR, Insignia BRD/DVD/SACD/DVD-A, Denon AVR-890, Fronts: Polk Monitor 70's, Rears: Deftech Mythos Gems, Center: Polk CS1, Sub: Polk PSW-505
  • AR15223
    AR15223 Posts: 13
    Yeah I seen the sub and towers on newegg for a good deal, just wondering how to the monitor series matches up with the tsi 300
    Home Theater Setup
    BluRay: PS3 Slim
    Xbox 360
  • polkfan38
    polkfan38 Posts: 360
    Only instruments might tell the difference between the Monitor series and the TSi line. It is mostly cosmetic.
    Things are more like they are now than they ever will be!
  • mdaudioguy
    AR15223 wrote: »
    It's been said on here 100+ times that the Monitor and TSi lines are essentially the same sonically. Timbre-matching won't be an issue. They just won't look alike.
