How to convert blu-ray to ipad/ipod/iphone
didilili
Would you like to convert Blu-ray movies to ipad/ipod/iphone? Currently, more and more people have their own ipad/ipod/iphone. Therefore, some people may encounter the problem of how to convert Blu-ray to ipad/ipod/iphone. Here is a solution for this problem.
Then DVDFab Blu-ray Ripper will give you total freedom. It's a Blu-ray to ipad/ipod/iphone converter with fast speed, high quality and flexible settings. It also can rip and convert Blu-ray to various other video/audio formats for playback on multi-equipments. Follow me to have a look at the easy conversion of Blu-ray to ipad/ipod/iphone with DVDFab Blu-ray Ripper.
Now I will show you how to convert blu-ray to ipad as an example and then you can do the ipod and iphone option in the same way.
Step 1) Start up DVDFab Blu-ray Ripper and select Blu-ray to iPad
Step 2)Load Blu-ray disc or Blu-ray files for your iPad Before the Blu-ray to ipad conversion process, you need to load Blu-ray. You may insert your Blu-ray disc to BD drive, or you can copy the Blu-ray files to your PC, you may also import ISO files on your PC by clicking the ISO icon button.
After loading the Blu-ray, you may preview the Blu-ray movie with this Blu-ray Ripper. Meanwhile, you can also select certain titles to convert. Now, select the wanted titles for your Blu-ray to iPad conversion.
In this example, we are converting Title852. (See the illustration below)
Step 3) Customize your Blu-ray to iPadconversionSettings
Step 3.1 Title Start/End settings DVDFab Blu-ray Ripper has a setting panel that enables users to chapter range for specific blu-ray to ipad conversion.
You may select the start and end chapters for the highlighted title you desired to convert. The following screenshot depicts the way to select titles for your blu-ray to ipad conversion.
Step 3.2 Open Queue DVDFab Blu-ray Ripper offers a conversion Queue. With this Queue, you need not to convert the wanted files one by one. Just use Queue to start the batch Blu-ray to iPad conversion. In the Queue, you can define different parameter for each converted files. Your Blu-ray to iPad conversion would be highly accurate in quality. Copy: Sometimes, you may need to convert another copy of the same file. Dont worry, here you can simplyclick the copy buttonin the Blu-ray to ipad conversion queue interface. At the same time, you may also create a new task for the same title yet output another format listed in the drop down profile selector. Remove: Blu-ray to iPad conversion process is flexible and joyful. You can freely remove the task you selected in the Queue. If a title is removed from the task queue, it will be deleted from the Title List (in the main window) as well.
Step 3.3 Settings for the Blu-ray to ipad conversion DVDFab Blu-ray Ripper allows you to set specific settings for the Blu-ray to iPad conversion.
Please click on Edit button, open Conversion Settings window. You can adjust the output parameters like output type, audio/video format, frame resolution/aspect ratio, and rename the output file, etc. .
Step 3.4 Edit the Output Video Effects with the iPad Blu-ray Ripper
>Resize the video screen for Blu-ray to iPad Conversion DVDFab Blu-ray Ripper allows you to resize the video screen for the output videos during the blu-ray to iPad conversion process. You may crop or set the pixel resolution for the output video during the process of convert blu-ray to iPad. Here you can select the suitable aspect ratio, frame resolution and visually check the different scene's output effect by draging the slide bar in the lower right area, and the detailed parameters of source/output file in the left bottom corner.
Note:If you don't want your converted video to be stretched and made taller, please don't change the Source Aspect Ratio before converting.
>Crop Here you can cut off the black edges and unwanted area by easily draging the frame-mark on the video screen of the source file, you also can type the number in the Top/Left/Right/Bottom box to crop accurately.
Note: If you want to keep the aspect ratio of source screen, you need to check this option before cropping the menu letterbox to allow you to resize output.
Step 4) Start to convert Blu-ray to iPad After accomplish all the settings, click Start. The conversion will do it work. You can track the conversion process from the progress bar at the bottom of the interface. If you have checked the option Automatically shut down the pc when done, the computer would automatically shut down after conversion finished. Till now, your conversion process is almost complete. The last step, you need to transfer files to iPad.
Step 5)Transfer the converted file to your iPad with iPad File Transfer DVDFab also provides a function of iPad file Transfer. To transfer the converted files from PC to your Apple iPad, you need to launch iTunes, connect your iPad to computer with the USB dock cable, then synchronize the converted files to your iPad. Now you can enjoy the movies on your iPad freely!
There are some other wonderful software you may like.
DVDFab Blu-ray copy
DVDFab ipad/ipod/iphone video converter
DVDFab Blu-ray copy
