Different OHMs on front/rear channels of the amp
Vital
Let's say i have 4ohm speakers in the front and 2ohm speakers in the rear.
How does it work with a 4-channel amp that does both?
Fronts will still "get" 4ohm and rear will "get" 2ohms or both will have 3ohms?? or either 4 or2 for all 4 speakers??
Really not sure how it work in this case.
Amp i'm talking about is PA500.4 but i'm sure same would apply for any other amp that works with 4 and 2ohm speakers. (and is rated to rms watts accordinly)
2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
Kenwood DNX 5140
Post edited by Vital on
Just the answer i wanted to hear
thanks!
I'm assuming all 4-channels are the same way, right? Just curious2008 Nissan Altima
Kenwood DNX 5140
Polk Audio PA500.4 and PA1200.1 -
Yes. If your amp can handle 2 ohm stereo loads, then itll play the rear speakers at 2 and the fronts at 4.polkaudio sound quality competitor since 2005
What speakers are you using that are 2ohm nominal?-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
^^ that + there are 2 ohms speakers. 6.5'' Image Dynamics CX62 is what i was looking at. they are 2 ohms. There's also a lot of 6.5'' midbass woofers out there. Don't even have to go far, MMs are 2.7
2008 Nissan Altima
Kenwood DNX 5140
