FXi A4 Mounting Options
PhoenixMage
Is it possible to turn the FXi A4 90 degrees so that they dont sit as high and expect to still get a reasonable surround experience? Or is it possible to mount the back to the ceiling without a noticeable reduction in surround quality
Alternatively can anyone recommend any good speaker mounts for the FXi A4's?
Thanks,
Tony
Thanks,
Tony
Post edited by PhoenixMage on
I've got fxi3's mounted from the ceiling and they sound great. I just used these cheap ones and they've held up nicely.
http://www.amazon.com/VideoSecu-Universal-Satellite-Brackets-Ceilings/dp/B002VFVQWS/ref=sr_1_15?ie=UTF8&qid=1290541317&sr=8-15 -
Sorry I was thinking of mounting them with the backs to the ceiling and the speakers pointing down.
