Which Speakers
acs_rpeters@msn
I am looking to buy some front speakers. I currently have an TX-SR606 AVR and Polk RM95 surrond sound. I looking at also getting Polk Audio DSW microPRO 2000. I have been looking at the VM30 and RTiA7 as options. Any recommendations would be greatly appriciated.
Post edited by acs_rpeters@msn on
welcome to Club Polk
Have you checked out
http://www.polkaudio.com/homeaudio/index.php
looking for floor standing, bookshelf, built in ?
budget range that you are interested in spending ? -
Looking for floor standing. Looking at the referbs at plk ebay in the 500-800 range and another 300-500 for the sub. Want for a comb of HT and music.
Im also starting to consider the Monitor 70s. Based on current receiver and combination of HT and music do you think the 70 would do go or should i go up to the RTiA7
Thanks, went with Monitor 70, Newegg had for 169 each. 2 minutes later they are listed at 249 each so got lucky there. C2 center was 99.
I did get CS2 as well. Any ideas how these will sound with current surround speakers Polk RM95
