Resonating bass on SDA SRS?
FheBlackPassat
FheBlackPassat Posts: 42
edited November 2010 in Vintage Speakers
I can hear some wierd noise on mine at very specific frequencies. I swear its the PR basket resonating on certain notes that are struck with a bass guitar.
Has anybody else experienced such an event on their SDA SRS's?
Post edited by FheBlackPassat on
  • ben62670
    ben62670 Posts: 15,969
    Pull the passive out and see if the spider is damaged.
    Ben
    Ben
  • AudioGenics
    AudioGenics Posts: 2,567
    check placement of the speakers
    also make sure that nothing external is vibrating.
  • ben62670
    Also check and see if all the driver screws are tight.
    Ben
    F1nut Posts: 51,774
    The paper/Styrofoam parts at the rear of the PR have been known to come unglued resulting in odd sounds. Remove the PR and if that is the problem, it will be obvious.
  • Audioquest
    Audioquest Posts: 104
    Pull the drivers and see if any of the wiring is vibrating against the inside of the enclosure. I know most speaker manufacturers never do much to secure the wiring so this won't happen.
    HT: Polk SDA SRS 2.3 main fronts, Klipsch RC-25 center channel, Polk RTi-150 rears, M&K V1B sub, Denon AVR-5800, Samsung 52" LCD, Sony BDP-S550
    2 Channel: Carver ALS Platinum, Audio Research LS-2B preamp, Counterpoint SA-100 amplifier, Integra CD player, Denon SL7D tt, TC750 phono pre, Nikko tuner
  • FheBlackPassat
    Well I've done all the obvious external checks. Next step, take out the PR and start investigating. What it sounds like to me is that at certain frequencies the basket on the PR is resonating. I can't say 100% for sure but it sure sounds metalic to me.
    If this helps at all, I really notice it when I listen to the Tool
  • AudioGenics
    some folks apply a "dynamat" sound absorbing type material on the basket
    http://www.dynamat.com/products_architectural_dynamat_xtreme.html
  • FheBlackPassat
    Oh really?! So I'm not just hearing things? Dynamat, know it all too well. Many an hour applying it to the inside of my car.
  • dorokusai
    dorokusai Posts: 25,576
    F1Nut and Ben have already pointed you in the right direction.
  • AudioGenics
    yeah definitely need to verify all the component ie passive radiators are in good condition
    also do a search on dynamat
    there are lots of threads
    here is one interesting one for example
    titled : Fun With Foam: SDA Driver Basket Insulation
    http://www.polkaudio.com/forums/search.php?searchid=16612440
    http://www.polkaudio.com/forums/showthread.php?t=74306&highlight=dynamat+darqueknight
  • OldmanSRS
    OldmanSRS Posts: 419
    Check the front to back braces inside the cabinet. They are hot glued and known to break loose.
    '65 427 Shelby Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub (Original OEM)
    '20 HSU VTF-3 Sub (three more, 100% cloned)
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '88 Adcom GFA-555 (a second one upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Fosgate 360 Digital Space Matrix
    '89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
    '91 Kenwood Basic M1D Amp
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
    One PGA2310 based custom built remote volume control
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • FheBlackPassat
    Holy crap, I'd like to listen to my speakers for a while before I rip them all apart:smile:
    Oh well, might as well get this stuff over with. This is a good weekend project without kids around. Ill have to figure that one out. Yeah right.
