wiring question...help me out Dodge!
Ok, I have my Focal 165s in. Basically got an amp for free, but not the one I eventually plan to have. It's an Eclipse EA3422. It's giving me 50w x 4. I could care less about my current rear speakers and my Focals are not getting enough with only 50, according to the specs. They need to run at least at 80 from what I gather. Should I bridge the 4 into 2 to run them giving me 140X2 at 4ohm? I think I know how to wire this, but I'm not sure about the RCA jacks in the front of the amp. It's set up X4, but I can pull the rears, then bridge the Focals. For the right side, I put the right+ in the rf+ and the right - in the rr-, then the opposite for the lefts? Fix my gains, switch to 2ch, and I'm ready to go? I learned this from some diagrams and a couple different sites, but I don't know much about how to fix the RCA cables in front. Let me know if I'm doing this right before I fry this! Thanks.
Post edited by MexicoDan on
Dan,
You'll wanna post this over in the Car Forum instead of here in the Home Theater Forum.......good luck...comment comment comment comment. bitchy.
