Lsi9!
Ericw2431
Ericw2431 Posts: 228
edited November 2010 in Speakers
Do any of you know how to clean the speaker grille cloth?! im starting to noticed a little fade in the cloth! my room gets really dusty at times and as i was wipeing and cleaning out furniture i noticed the gille was getting this drak gray color to it! anybody kno how to clean them?! many have sayed take the grille of and leave it of! but i perfer the look of them with it on! please anybody?!
Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
Post edited by Ericw2431 on
    F1nut Posts: 51,918
    Vacuum cleaner.
  • jimmydep
    jimmydep Posts: 1,305
    ^^^^^+ Lint roller.
  • janmike
    janmike Posts: 6,146
    Vacuum cleaner.
    +1 - Works for me.
    Michael ;)
    NORTH of 60°
  • Devlon
    Devlon Posts: 355
    I use a can of compressed air blowing out the grill cloth from the inside out.
    Living Room: HK AVR 354 as pre/pro, 2 x Polk Audio Micropro 4000, Adcom GFA-7500, 2 x Mirage OMD-15
    2 x Mirage OMD-5, 1 x Mirage OMD-C1, APC H15, Sony S790, Philips 52" LCD, Beogram 3000, FAT (Firestone Audio Tobby DAC), Harmony One
    Den: Sherwood R-972,as pre/pro, 2 x Velodyne SPL-1000R, 3 x Crown Drivecore XLS1500, 2 x Polk Audio Lsi9
    1 x Polk Audio Lsic, 2 x Polk Audio Lsifx, Sony S790, APC H15, Dspeaker Dual Core 2.0, W4S DAC 2, Keces DA-151
  • cheif pontiac
    cheif pontiac Posts: 138
    Good old water. You can use a wet rag. Just wipe lightly. If you have heavier spots blot them. If you use a vacuum make sure you have a soft attachment so you do not snag the cloth.
    System:
    Samsung LN46C630
    Receiver: Yamaha RX-V1
    DVD/Blu: Denon 2910/Playstation 3
    Front mains: RT16
    Front presence: F/X 500i
    Center: CS400
    Rear surrounds: RT1000p
    Rear center: RT7
    Subwoofer: PSW505 X 2
    Marantz 2252B
    Technics SL-Q2 turntable
    Kef Q50
  • AudioGenics
    AudioGenics Posts: 2,567
    I use a natural hair soft paint brush
    Light vacuuming will work. I've also used a sponge that has good integrity, a bit moistened, to remove children's chalk marks and dust from the grille of a CSI-3 with success....but you have to be gentle and give it time to dry well.
    The grilles on the LSIs and actually VERY thin so I'm sure vacuuming will remove any 'dust'...it probably won't do well against anything that has 'adhered' to the grill (such as the above description).
    cnh
  • skrol
    skrol Posts: 3,456
    Having 2 white cats is a pain. I usually vacuum them with the soft upholstery brush but sometimes I have to get out the sticky lint roller. I use the roller because the sound of the vacuum sometimes scares the heck out of them.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,456
    I was talking about the speakers of course.
    Stan
    Main 2ch:
    HT:
    Other stuff:
