Todays Project
ken brydson
ken brydson Posts: 9,107
edited November 2010 in DIY, Mods & Tweaks
Well I finally got around to wall mounting my plasma. It sat just fine on my TV stand but the problem was I didn't have a spot for my center channel. When we first got the entertainment center I had a 36" Sony XBR tube. I built a shelf for that spanned the columns for the center but when I later upgraded to a 42" LCDRP I never got around to building another shelf and the center got moved on top of the light bridge. Since moved up to a Panny 50" G10 and couldn't take it anymore.:wink:
I was looking around at wall mounts to would extend considerably from the wall and at the stores they are damn expensive ($250-300). I then decided to check out Monoprice and ended up getting a really sturdy mount for less than $75 shipped. They had cheaper ones but in reading the reviews the single arm ones seemed to be prone to sagging so I got one with cast aluminum scissor arms that was very highly reviewed. This thing is awesome. Very heavy duty and versatile.
I am very pleased with the results and it sounds so much better with the center down where it's supposed to be....
