Spike question
jonicont
jonicont Posts: 281
edited November 2010 in Vintage Speakers
Thinking of putting spikes on my 2BTL's. Do those little plastic feet unscrew?. If so, what size thread are they. Thanx
DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
Post edited by jonicont on
  • inspiredsports
    inspiredsports Posts: 5,502
    jonicont wrote: »
    Mine seem to be teflon or white plastic, but integrated onto a nail and tacked directly into the fiberboard base, and they would need to be gently pried off. Replacing with threaded is on my winter project list.
    I would then need the spikes that come with the tee-nut and to drill out the base and install the tee-nut.
    Polk did change features constantly so it may be possible yours unscrew, but my thoughts are that 2B's never had the threaded type.
    This is the small version, but I'm linking it so you can see the screw-in nut portion that is more secure than just a standard tee-nut . . .
    http://www.amazon.com/Dayton-DSS3-BC-Black-Chrome-Spike/dp/B003BFPDS0/ref=pd_sbs_misc_5
    My favorites are these, but they don't come with the tee nuts . . .
    http://www.amazon.com/Sound-Isolation-Cones-Floor-Spikes/dp/B001FAAE28/ref=sr_1_22?s=electronics&ie=UTF8&qid=1290272796&sr=1-22
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    I just realized the direct link to the SuperCellAudio website (no afilliatiion) is actually cheaper than their amazon.com price if you happen to like these . . . http://www.supercellaudio.com/Floor%20Spikes.htm
    NAD SS rigs w/mods
    GIK panels
  • jonicont
    jonicont Posts: 281
    Thank you
  • thsmith
    thsmith Posts: 6,082
    Myesound.com points n pads
  • inspiredsports
    OK, granted the SuperCellAudio Brass spikes (available in brass or black coated brass) are 1/4" versus 5/16", but a set of 4 is rated at 170 pounds. The SuperCellAudio spikes cost $4.50 each delivered ($36 for 8) and come with:
    - - - Threaded Brass Spike
    - - - Matching Round Brass Knurled Nut
    - - - Matching Round Brass Floor Pad
    The Myesound product is just a spike for $10, no nuts offered, floor pads are $4, shipping is $10 so 8 spikes and pads (no jam nuts) would be $122.
    I do not get the recommendation as the OP has SDA 2B's that weigh half of what the $36 solution will carry. For SDA SRS's, the 5/16" version may be the right suggestion, but I'll bet the $36 product would even support the extra 15 pounds there.
    NAD SS rigs w/mods
    GIK panels
    F1nut Posts: 51,766
    To the OP, the 2B's never came with threaded inserts. Remove the plastic nail in feet, drill some holes and hammer in some 1/4-20 T-nuts.
    All SDA's that came with screw in feet/spikes are using the 1/4-20 thread pattern, so I'm not sure were 5/16 came from.
    Why Mye Sound? Because they are turned from solid brass billet, none of that double threaded shaft stuff. Jam nuts? Never needed those.
  • inspiredsports
    Where can I get T-Nuts that are turned from a solid brass billet?
    I've found stainless steel, but I think they still impart a bit of "harshness" just like those damn cheap 1/3 of the price double threaded jobbies :biggrin:
    P.S.: I've never used the jam nuts either, I'm just impressed you get them essentially for "free" in the price. I just ordered a second set (SuperCellAudio) a few minutes ago as I'm about to install them and Larry's rings on my 2B's. The unused nuts make cool paper weights and you can knock people out with a well aimed toss.
    NAD SS rigs w/mods
    GIK panels
    F1nut Posts: 51,766
    LOL......maybe we can talk Larry into making some.
  • inspiredsports
    Well, I guess we'll have to put up with the compromise :rolleyes:
    On a serious note, the tensile strength of brass is 200,000 Pa (pascal units) whereas even basic carbon steel is 640,000 Pa. The threads, and especially the junction of the threaded part to the cone is extremely weaker on the solid brass version.
    If you were ever to drag a heavy speaker (not that anyone would, I'm sure everyone invites over 4 friends to lift and move their SRS's), an extended cone could snap right off where I'll bet my life the steel studded version would not.
    NAD SS rigs w/mods
    GIK panels
    F1nut Posts: 51,766
    Like any good man, I put mine all the way in.
  • Vette C6.r
    Vette C6.r Posts: 1,560
    TMI - F1 :smile:
  • inspiredsports
    I've been lucky like that too :biggrin:, but back to speakers, I've seen floors that are so far off it's not possible. I'll stand by my recommendation of the cheaper "composite" spikes.
    NAD SS rigs w/mods
    GIK panels
  • dorokusai
    dorokusai Posts: 25,576
    Plus they use a lock nut. I've owned a dozen sets of spikes from Mye and not a single angry, objectified or mislead 1/4-20 thread.
  • Schurkey
    Schurkey Posts: 2,122
    And to show how tightfisted I am:
    Six hardware store T-nuts in 1/4-20.
    Six Grade 8 bolts, 1/4-20 X 1.25
    Six 1/4-20 nuts
    Cut the heads off the bolts, sharpen the end to a point on a bench grinder. Install three T nuts, bolts, and jam nuts per speaker by drilling holes of suitable size to press the T nuts into; and with enough depth to allow the bolt to thread in nicely. I chose two in front, one in back. Adjust height of spikes to achieve verticalness before locking the jam nut.
    If I have two dollars in hardware cost and two hours in labor (including shopping and drive time!) I'd be surprised; but of course all this was done ~fifteen years ago.
