Tv Mount Question
Brian131
I want to mount a 22"-26" lcd tv in my kitchen and also run coax to an hd cable box. The problem I am having is finding a mount that will also hold the cable box. All of the mounts that I see online and in stores only hold the tv. I explained this to a salesperson at an electronics store this past weekend and he looked at me like I was crazy.
Does anybody have any suggestions?
Panasonic P42S1
Panasonic BD 65P-K
Yamaha Rx v465
Polk Audio Rm75
Polk Psw 505
X Box 360 Elite
Comcast Hd/Dvr
Harmony 510
I strive to be the kind of person that my dog thinks I am.
Panasonic BD 65P-K
Yamaha Rx v465
Polk Audio Rm75
Polk Psw 505
X Box 360 Elite
Comcast Hd/Dvr
Harmony 510
Post edited by Brian131 on
Hi - have you looked around on racksandstands.com?
http://www.racksandstands.com/TV-Mount-Accessories-C8538.html
They seem to have mount accessories that'll hold other video components.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
It's hard to find ones that hold a cablebox too.. because it'd have to hang down off the back of the mount. Have you looked at amazon or monoprice?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
LOL, I would have looked at you crazy as well.
Get a small shelf to put the cable box on under the TV.(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
(2) Panny DMPBDT110 3D Standalone Players
Panny 60" 3D Plasma TC-60ST30
Panny 50" Plasma TC-P50G10
Panny 50" 3D TV TC-P50GT25
Denon AVR-891
Harmoney One Remote
Polk Monitor 70's,Polk CS2, Polk Monitor 40's -
Mount the TV with a standard mount and put the cable box in a cabinet (one of the kitchen cabinets). Then use a IR repeater for the signals. You can get them for about $40. That way the box is out of sight, not all gaudy looking in the middle of the kitchen but will still work perfectly. This is how I have the TV set up in my living room with the cable box in the basement.
