What's wrong with this picture?
Main Surround -
Post edited by nguyendot on
I give up...
what's wrong ?
i can't make out the connections since there is no detail in the image.
but if the seller just wanted to capture a picture of the back of the unit or 2 units
it looks decent. Does not necessarily need to be a complete working connection -
I believe he is using both the line in RCA's and also the LFE in...a no-no from my limited understanding"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
but you only see one end of the connection ?
I cannot see what is on the other end ? -
EndersShadow wrote: »I believe he is using both the line in RCA's and also the LFE in...a no-no from my limited understanding
You get the cookie.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Come on people. You aren't supposed to use speaker level connections and LFE at the same time. Those aren't RCA's since there are EIGHT of them.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
So buy it and rescue it from this horrible seller, and then you can do a genius textbook job of hooking it up :rolleyes:VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
I want to but the shipping on that sub would kill it, lol.Main Surround -
http://www.polkaudio.com/downloads/manuals/home/PSW650manual.pdf
see diagram 5
The “high pass crossover” switch
(Figure 5) on the PSW650 gives you
the option of filtering bass from your
main front speakers for the purpose
of increasing power handling and
lowering distortion at high volume
levels.
see diagram 8
If the subwoofer output jack is filtered,
we suggest using hook up OPTION #1
or #2. If it is unfiltered, connect the
subwoofer output jack to either of the
line level “IN” jacks (Figure 8). With
Dolby Digital systems, select subwoofer
as “on” or “yes” in the “speaker set up”
or “bass management” function of your
electronics
see diagram 10 (front speaker)
This control adjusts the frequency range
over which the subwoofer operates. This
control only affects signals that are sent
through the line level “IN” jacks and the
speaker level inputs. It has no effect on
signals fed into the LFE input. When
using smaller main speakers, the upper
range of the control will probably yield
Please explain what is wrong again ? -
Whoa whoa.. you can do both speaker level and LFE on this sub simultaneously?Main Surround -
I had directions with my sub on how to use both.Mains - LSi9's
Center - LSiC
Surround - pair of TL3's
Amplification - Parasound 2125
AVR - Onkyo 706
CD/SACD - Onkyo DV-SP506
SUB - MartinLogan Abyss
55" Panasonic Viera TC-P55GT30 3D
Bluray - DMP-BDT310 Panasonic -
hey... I suffer from the same syndrome
ask for map directions ( i luv to cruise )
read the instruction manual ( then whats a warranty for ?) -
Both at the same time. I don't think so.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
but we don't know
how the owner is actually using it in his system
the actual application
by way of just the picture.... -
there is a PSW 303 listed on E-bay where the guy has both speaker wire and line level input hooked up.
http://cgi.ebay.com/POLK-AUDIO-PSW-303B-POWERED-SUBWOOFER-/110610603754?pt=Speakers_Subwoofers&hash=item19c0e7deeaSystem:
Samsung LN46C630
Receiver: Yamaha RX-V1
DVD/Blu: Denon 2910/Playstation 3
Front mains: RT16
Front presence: F/X 500i
Center: CS400
Rear surrounds: RT1000p
Rear center: RT7
Subwoofer: PSW505 X 2
Marantz 2252B
Technics SL-Q2 turntable
Kef Q50 -
^^smh
