Monitor 30 mounting
robertstj9
I bought a whole new system through new egg this week. Monitor 60s for the mains, CS2 for the center, PSW505 for the sub and Monitor 30s for the rear.
I guess in my mind I had envisioned the Monitor 30s to be much smaller and was hoping to ceiling mount them with a bracket of some sort. Does such a thing exist for these speakers? These are much larger and heavier than I had hoped.
If that is not a possibility, would the RC60i in-ceiling speakers be adequate for to match up with the rest of the system. Any other ideas? I am pretty much limited to a ceiling mounted solution without destroying drywall, which is not an option.
Thanks for the help.
Post edited by robertstj9 on
robertstj9 wrote: »I bought a whole new system through new egg this week. Monitor 60s for the mains, CS2 for the center, PSW505 for the sub and Monitor 30s for the rear.
The Monitor 30's have keyhole mounts built in so you should be able to use those with some anchors or bolt. If not purchase a set of PinPoint AM40 wallmounts. I used them with my Monitor 40's and they work great. Check out pics in my System Showcase."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
