HTR Pioneer VSX-515
NeilGabriel
NeilGabriel Posts: 1,487
edited November 2010 in Electronics
Looking to put together an inexpensive HT system for the son. This Pioneer VSX-515 is near me. Seems they had a model S and K.
Anyone offer advice. I've seen some good reviews on the 515, but I assume it is pretty low end.
thanks....
Post edited by NeilGabriel on
    The 500 series is now, Pioneer's entry level model. Many were 5.1 some 7.1 depending on the year. Probably rated as 100/channel....but more like 45-50 watts. It's certainly an acceptable AVR for a cheap starter system.
    My first Dolby Digital AVR was a Pio VSX-711--good enough for my needs at the time. It still does Basement duty quite well with some Garage sized L/R speakers and a Pio center?
    The important thing is that you don't PAY too MUCH for that!
    cnh
  • nguyendot
    nguyendot Posts: 3,594
    It is pretty low end. S and K are Silver and blacK. Should work fine for a kids first system though...
    Main Surround -
  • NeilGabriel
    thanks a lot...
