RT10 X-Over
I have a pair of vintage RT10's that I really like.
Problem is one of them is playing louder than the other.
Not sure if it is VC related, or weak cap.
It is not my system, as other speaker pairs play fine.
How to identify the problem?
Wondering if I replace the caps with same values should I replace the resistor in the x-over also (1ohm 5watt)?
If so, what brand resistor would you recommend?
Leave the inductors alone?
I was thinking Solen poly on the tweet, and electrolytic on the woofer.
Would it benefit the woofer by replacing with a Poly cap also?
