Computer battery backup
jim 249
Hi All; I need some advice on buying a battery backup that I could use on my modem in the event of a power failure. How big of a unit would I need to keep my modem going for a few hours to keep surfing the net or watching a football game? My laptop battery is good for 3 hours or so on a full charge. Thanks for any help!:biggrin:
http://www.apc.com/products/category.cfm?id=13
apc ups Uninterruptible Power Supply ( or similiar product )
contact tech support for specific application and sizing. -
What is the power supply rating for the modem (are we talking analog modem like dial up or cable/dsl modem?) in voltage and ampere? -
The modem is clearwire rated at 12 volts 1.5 amps and the router is 5 volts at 2 amps. No wattage is listed for either. Thanks -
Voltage multiplied by amperage = wattage. So the modem is 18 watts and the router is 10 watts. So your total load is around 32-35 watts considering that transformers are not 100% efficient.
According to the APC wattage calculator a 750va rated UPS will net you around 140 minutes and a 1500va rated unit would be double that. -
Hi jinjuku; Thanks for the info!
and... (to state the obvious)... you can also plug your notebook's adapter to the UPS, to prolong its runtime past the stated 3 hours...
