Best 2 din configuration for Maruti Ritz
dhiren_hm
Hi, Am buying a new Ritz and need to know about good configuration within a budget of Rs.15k. I have decided upon 2 things -
1. I will go for 2 din HU as it goes well with the interiors of Ritz
2. I am thinking of going for JBL speakers in the doors only (not in parcel tray)
Can anyone suggest good configuration with above 2 things? Also the local dealer here told me that amplifier is not required as I am not going for subwoofers. Is it true?
Post edited by dhiren_hm on
If you're going to run without an amp, spend a bit on sealing your doors. The installer will seal the doors with dynamat extreme. Ask for this.
