Question about rear speakers
Maisum
Everytime I read peoples post on here they say you don't need rear speakers...why is that?
Would rear speakers make the car sound better? How does it sound in the back?
I dunno just makes more sense to have surround sound over mono...
Post edited by Maisum on
Why have surround sound when music is recorded in stereo? You have a speaker on each side in the front, so it is stereo, not mono.
The reason most advise against rear fill is that having too many speakers degrade your sound quality. You have sound coming at you from 4 different locations at 4 different distances. So it tends to 'blur' the sound, for lack of a better term as youre hearing the same music, but at 4 different times. Even though its literally milliseconds apart, it blurs the detail you can get from only having 2 different locations that sound is coming from (the front left and front right).
Also take into account, when you go to a concert, the band is always in front of you and no sound comes from the rear.
BUT...if you like to have sound coming from the front and the back, screw what we say and do what you like. Its your car and your ears!
Yup. You want the fewest amount of speakers possible. For sheer volume and output more speakers would be a better way to go I suppose but for proper or even decent sound quality, it doesnt work.
Benefit to this is you can put the money you wouldve spent on rear speakers towards a better quality set of speakers for the front.
For the average Joe just looking for some decent tunes to listen to while driving back and forth to work, go for some rears, cant hurt. But if your goal is the best SQ you can get, its gotta be a single set of quality speakers up front.polkaudio sound quality competitor since 2005
Never thought of it like that, thanks guys!
Got alot to learn... -
continuing on this thought.. perhaps I could use my HU to send everything through the front speakers to see what I think about not having any sound from the rear?
Would this cause any issues?
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
continuing on this thought.. perhaps I could use my HU to send everything through the front speakers to see what I think about not having any sound from the rear?Would this cause any issues?
Right now my car is stock with no amp. Is it better if I just send the audio to the front using the HU or disconnecting the back speakers for now?
It'll also depend on what speakers you have. If you have 3.5's up front and no sub, it'll sound like ****.
And no matter what speakers you have up front, you'll lose overall volume by switching off the rears. So this won't necessarily be an accurate representation of tonallity differences. Instead pay attention to the change in detail, imaging and soundstage.polkaudio sound quality competitor since 2005
Thats what I'm going to try Maisum.. My stuff isn't stock, but I'm going to send my sound solely to the front starting this AM..
This was an incrediblely useful thread.. I never thought about my rears degrading my sound.. I have some pretty decent Focal's up front, it'll probably sound much better
Pre: Dodd ELP
DAC: W4S-Dac2
Jason, what are you using as a hu?
I've spaced out the number.. its a Pioneer.. Had it a couple years.. full, flip-down face.. cost around $300 i think (thats all i can remember off the top of my head, lol)
Why? I don't know if it has the Time Alignment feature... I don't remember see that any where..2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
lol . No prob. Tell us how it sounds with only fronts. -
I'll post what Focal's and HU I have... have the boxes at home.. just don't remember (and I'm at work!)
Pre: Dodd ELP
DAC: W4S-Dac2
Well, I only had a 5min drive home from work.. but only utilizing my fronts was quite a bit more pleasing to my ears. Seemed far more natural and was more enjoyable.
Granted only 5min, so i'm curious what i'll think as i log more miles this way.. but was positive enough that I felt the need to post now
P.S. My HU is a Pioneer DEH-P700BT and my Front are Focal 165v2's2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
I've tried the same thing, and actually I like the sound mostly toward the front, with just a tad bit coming from the rear speakers. Perhaps it's psychological, but without some rear fill, I can't get past the feeling that I have a gap between my front soundstage and my sub... So basically, I've just set the fade closer to the front.
mdaudioguy wrote: »I've tried the same thing, and actually I like the sound mostly toward the front, with just a tad bit coming from the rear speakers. Perhaps it's psychological, but without some rear fill, I can't get past the feeling that I have a gap between my front soundstage and my sub... So basically, I've just set the fade closer to the front.
First off, there is no "wrong" way to set it up really unless youre competing or something. Youre the one shelling out your hard earned bucks for this gear, set it up with the sub up front and the speakers in the rear if thats what you like.
Its not so much a gap between the front stage and the sub as it is the sub is hitting your ears way later than the rest of the music which makes it very easy for you to locate it in the rear. If you had time alignment, youd add delay (usually in the 3 ms range) to all your speakers except for the sub so that the sub is the first thing you hear. Your ears will queue on the thing they hear last and your sub will image up front.
Also, the higher you go over 63 Hz on the sub, the easier it is to locate. You can try turning the subwoofer crossover down (if you have one) and youll notice it pulling to the rear less.polkaudio sound quality competitor since 2005
