Polk
zgreatwhite
zgreatwhite Posts: 3
edited November 2010 in Speakers
Newegg had the following deal
Polk Audio CS1 Series II Center Channel Speaker (Black) Each
$99-$35=$64
$2.99 Shipping.
Is there any reason I couldn't use 2 of these in a typical stereophonic setup?
$35 off w/ promo code EMCZZYX64, ends 11/15 Polk Audio CS1 Series II Center Channel Speaker (Black) Each
* 20-125W
* Tweeter Complement: one ...
* Driver Complement: two 5...
* Type: Center Channel Speaker
* Driver Units: Tweeter Complement: one 1" cloth dome Driver Complement: two 5.25" Bi-Laminate driver
* Power Rating: 20-125W
* Frequency Response: 55Hz-25kHz
* Model #: CS1B Series II
* Item #: N82E16882290210
* Return Policy: Standard Return Policy
* Was: $199.99
* Now: $99.99
* $2.99 Shipping
Post edited by zgreatwhite on
  • nguyendot
    nguyendot Posts: 3,594
    The speaker is intended as a center channel, I guess you could get two and run them in stereo, but they'd have to sit horizontally not vertically.
    The dispersion pattern would be kind of far off and you'll get some irregular imaging from them.
    Personally I wouldn't recommend it.
    Main Surround -
  • dorokusai
    dorokusai Posts: 25,611
    It's not ideal but I find no harm in using that particular loudspeaker as a stereo pair. Go vertical and keep the tweeters on the outside. The Polk RM series is flexible in this way as well. Martin Logan and NHT also have L/C/R speakers.
    If the tweeter was angled or used a dispersion bracket, sure you'd have major problems but it doesn't.
