LSi25 setup question
pmckeealaska
pmckeealaska Posts: 808
I recently moved and forgot how I had my system hooked up and wondering if I ever had it setup for best perfromance. I have a full LSi 5.1 setup with LSi25's as my two mains and have a NAD T763 reciever and Rotel 1080 2 channel amp. My question is mainly about the 25's. The T763 has 2 subwoofer outs and I have the subwoofer cables running from the reciever to the "line level in" on both speaker subwoofers. I have kept the binding posts on and the reciever is set to a crossover frequency of 80Hz. Is this an optimum setup for these speakers? Should I be running the subwoofer cables to the "lfe in" on the speakers subwoofers? If so, should I remove the binding posts? Finally, should I have the 25's set to "small" or "large"? Many thanks for any help you can provide. I've had these speakers for 6 years...maybe I should have asked these questions sooner....I wonder if I've been missing out on even better speaker performance??
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
    txcoastal1 Posts: 13,520
    edited November 2010
    Run them small, LFE, binding posts off
  • ben62670
    ben62670 Posts: 15,969
    Don't run them small. That setting is almost always 120hz or higher. Manually set them to cross over at 80hz.
    Ben
    Ben
  • pmckeealaska
    Thanks Ben. Thats what I thought. When you say manually set them, you mean the subwoofers, right? I have the reciever crossover freq. set to 80Hz already. Should I be using my subwoofer cables at all? To my ear it sounds better with the cables but I'm not sure if I'm in danger of "double filtering" with it this way??
    Music and Movie Rig
    LSiC Center Channel
    LSiFX Surrounds
    NAD T763 Reciever
  • ben62670
    On your 25's I think it has an XO knob. Just turn that up all the way(250hz or whatever) and let the receiver do the XO point for you. Yes use your sub out from the receiver. You may need a "Y" adapter to hook both of them up.
    Take care and enjoy.
    Ben
    Ben
  • dorokusai
    dorokusai Posts: 25,661
    Large.
