Front three
Hi guys. I have a question for all of you.
I am on the fence about what to do here. I am going to get three identical Monitor series speakers for the front of my HT. Either the 40s, 50s or 60s.
I never listen to anything too loud. The 40s would work fine but, I would need stands. The 50s would be good as well. I know they sound about the same as the 40s but, I would not need stands. The 60s would be kind of the "overkill" solution for me. But, would still be cool.
Which set up here would give me the most bang for the buck?
12X16 room and Denon 2310 BTW.
Thanks all
Thanks all
Things are more like they are now than they ever will be!
Post edited by polkfan38 on
I use 3 towers and I think it's great! If you can swing it, go for the 60s. Whatever you think is adequate now, you'll want to upgrade later, so go with your "overkill" solution to buy yourself a little time.
Thanks. I think I will go with the Monitor 60s. Having three identical speakers across the front is ideal. And I have the room to do so.Things are more like they are now than they ever will be!
Here is another question. I am also playing with seating positions. I am thinking of having a low seating position. If I do this, I could use Monitor 60s as surrounds as well. Is this a bad idea? Seeing as though there is not much going on back there. I did see a guy with 5 Infinity P362s in his HT. It was impressive to see but, I'm not sure how it sounded.Things are more like they are now than they ever will be!
I had towers for surrounds and had no issues with sound quality, I used my monitor 50's and effects were quite audibleSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
How did you get them above the seating area? The tweeter on the 50s can't be more than 30 inches off the floor.Things are more like they are now than they ever will be!
so does this mean your center speaker will be a tower like the m60? Why would you not a get a real center channel? or am i missing something here?
I personally feel bookshelves are better for a smaller room, because it is easier to adjust their position, making it easier to find the spot where they sound best, and it doesn't clutter/dwarf the room like the towers do. My 2 ch system is in a 12x14 room and I will be replacing the m70's with lsi7 in the future. As much as i like my M70s, they take up too much space in that room.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
Lietuvis91 wrote: »so does this mean your center speaker will be a tower like the m60? Why would you not a get a real center channel? or am i missing something here?
The best front stage is three identical speakers. Center channels are actually a compromise in shape and style. Most people don't want a full sized speaker under their TV for aesthetic and/or space reasons.
The term "real center channel" is an oxymoron ...because a "real" one would be one identical to the front L/R.
This is why I use a KG4 for my center to my ForteII's (Klipsch). Full size, and as close as I could get to matching. Blows my other "center" speakers out of the water.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
interesting... didn't know that, but it does makes sense.Living Room 7.1 HT Rig:
I say go for the M60's for the rears too if you have the room. I use RT1000p's for the rear with the powered woofer, trust me there is a lot going on back there if you let the right speaker do the ob.System:
Samsung LN46C630
Receiver: Yamaha RX-V1
DVD/Blu: Denon 2910/Playstation 3
Front mains: RT16
Front presence: F/X 500i
Center: CS400
Rear surrounds: RT1000p
Rear center: RT7
Subwoofer: PSW505 X 2
Marantz 2252B
Technics SL-Q2 turntable
Kef Q50 -
I suppose if you REALY crank it up there will be more back there. But, nothing I could tell that would justify towers! I have yet to get any of my speakers. I have a old set of Infinitys in another room. SL50s front and SL20s rear.
For the room I am setting up for HT, it will be three Monitor 60s in front. Monitor 30s for heights and the Monitor 40s I already have for the rears. With proper placement, this should be a great system!Things are more like they are now than they ever will be! -
Help! I am going to order the speakers tomorrow! I still can't decide! M40s, 50s or 60s up front????? Ug! There will be a sub crossed over at 80 Hz so, I don't need much bass extension.Things are more like they are now than they ever will be!
Overwhelming force is the way to go IMHO... go for the 60's....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Did they go and put cheaper tweeters on the Monitor IIs? I see "cloth" and not "silk"Things are more like they are now than they ever will be!
I chickened out and did not order the speakers yet. I have also rethought the purpose of the room. It will be mostly "movies" now rather than a 50/50 mix with music. I don't need it. So, here I am.Things are more like they are now than they ever will be!
