LSi Selection... Wait???
dcmartinpc
dcmartinpc Posts: 844
edited November 2010 in Speakers
OK, so I am having trouble making a decision... I have searched the forums and done a lot of thinking, but I wanted to ask a couple more pointed questions. Here is where I am at. I have 2 pairs of LSi9's and I love them. I have Monitor 70's in my living room 2 channel system that I would like to upgrade. LSi series can be had for a fairly good deal right now. Now here comes my conundrum. I am having some trouble deciding between another set of LSi9's ($500-$600) or trying out the LSi15's (~$1000) that I have never heard. I know the crossover points are different between those models and they are slightly different sonically. Now keep in mind, I have no intention of having a subwoofer in this system. Knowing I love the LSi9 sound, should I wait for the new LSiM 703 (LSi9 Replacement)? From what I understand these are coming out at $2000 a pair, which is quite steep. Should I jump on a pair of LSi15's? I am at the disadvantage of not knowing anyone within 2 hours of me that has the 15's for me to audition...
I would be driving these with a Parasound HCA-2200II amp, so no problems there.
Please help!
Don
Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
Post edited by dcmartinpc on
    nooshinjohn Posts: 26,075
    where are you located?
  • dcmartinpc
    I am in Niles, MI (49120)
    Don
  • PSOVLSK
    PSOVLSK Posts: 5,414
    I own both and my opinion is that without a sub in a two-channel system I much prefer the 15's.
    Is Lafayette Indiana close enough. I would be happy to let you hear my LSi-15's, and my SDA's. I must warn you however, that SDA's can be quite addicting.
    EndersShadow Posts: 17,743
    3 hours give or take via google maps.. (I'm bored so I looked it up)
    and John @ some point I promise I need to get up there.... you have all the gear I want to hear (LSi's, SDA's, tube and solid state amps)
    I think the reason I havent tried yet is because when I hear new gear I get the buying bug...
    And its only about an hour away lol
  • dcmartinpc
    I have had the SDA thought, because the 2200II is a common ground amp from what I understand. And I might be able to get them at a better price than $1000... I guess SDA's are on the table :) This is a dedicated 2 channel system.
    If I were to look at SDA's, what models would be a good place to start with a $1,000 budget?
    John, I think you just might be close enough for a weekend trip sometime, I have always wanted to hear SDA's! I would also love to check out those Tube Monoblocks you are building!
    Don
    dcmartinpc wrote: »
    Don
    You are welcome here any time...
    As far as SDA goes, it truly depends on room size and your ability to be able to place them properly. I would say that 2.3 TL's or 1.2TL's if you can grab them, but it seems everyone's number 1 choice of late would be a minty set of 1c's. Again, room size and the abilty to place then correctly are the main considerations. I would also recommend that you get your ears on some first so that you can figure out what sits your likes the best.
    I run 2.3TL's for my mains and have LSi-15's as surrounds for my 5.1 setup. When you are able, you can compare them side by side and make the call that suits you best.
  • veerapaneni
    veerapaneni Posts: 112
    I listened both Lsi9 And Lsi15s and prefered Lsi15s. If you have space get Lsi15.
    He went SDA-1c instead.:biggrin:
  • dcmartinpc
    Yeah I ended up buying a pair of SDA 1C's that have fully modded crossovers, Larry Rings, and I am upgrading them to the RDO 194 Tweeters! Excited is an underestimation! I can't wait for these things. The wife wasn't all that "thrilled" when I gave her a better idea of how big they were :eek: Then I showed here a picture of the 2.3tl's or the 1.2tl's that I want eventually :D
    She was better then...
    See what you did John! :smile:
    Don
  • dcmartinpc
    Oh, and I have all but made up my mind to drive these with my hot rodded Parasound HCA-3500 that should be here in the next couple weeks! The pair should be amazing....
    Don
  • mole'
    mole' Posts: 3,160
    OHHHHH!!!!! i like the sound of that
    how do you like the 2.3TLs with the LSi15s for surrounds? both are modded correct?
    what are you using for a center?
    mole'
    dcmartinpc wrote: »
    Don
    LMAO!!! I started with 1c's, scored a set of 1.2TL's and then down to the 2.3TL's because they slip under the mantle of my fireplace by the width of a gnat's ****!:tongue::biggrin:
    mole' wrote: »
    They are 100% stock and my center is a CSiA6. They seem to work well together.
    I am glad I could cause trouble... I mean help!:wink::cool:
  • mole'
    mole' Posts: 3,160
    hmmmmmm
    2.3TL fronts check
    CSia6 center check
    LSi15 surrounds missing
    mole'
    mole' wrote: »
    hmmmmmm
    2.3TL fronts check
    CSia6 center check
    mole'....you missing a speaker.....this must be corrected pronto ;)
  • mole'
    mole' Posts: 3,160
    i know.
    im SAD!!!!
    mole'
    He's missing more than speakers...:rolleyes::tongue::biggrin:
    Lord knows they need to change the For Sale section to "Items to be purchased used and then sold by Mole'"
