Svs!
Ericw2431
Ericw2431 Posts: 228
edited November 2010 in Speakers
have you seen the new svs sub?! LOOKS LIKE A KILLER and cheaper than the ultras!!!...the response was falt at 10hz and correct me if im wrong the amp is at 1000w!!! wow anybody have or consedring getting this sub?!
Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
Post edited by Ericw2431 on
  • dorokusai
    dorokusai Posts: 25,626
    Not really. I've owned 5 so far and a digit or two below what I already have doesn't mean anything to me. When SVS subwoofers hit 0hz, I'll be impressed.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    dorokusai wrote: »
    They already do. Engage the "POWER" switch, change from the "ON" position to the "OFF" position. There .... see ? :smile:
    From what I'm seeing, Eric, it looks like the +/- 3 db point is 16 hz. Am I seeing that correctly ?
  • Ron Temple
    Ron Temple Posts: 3,212
    Ericw2431 wrote: »
    With tweaking and room gain (if applicable) you can acheive a flat respone to 10hz with the SB13+. It will measure similarly to the Hsu ULS-15 in output (with some advantage down low and up top, but from what I'm told, with less distortion with rock hard limiters at max output that makes this sub behave with no distress. It's a great design for those who want compact and sealed. If you need more output and can handle the larger ported designs, you'll still get more output from the PB12+ and Ultra13.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
