Sub crossover
Vette C6.r
Vette C6.r Posts: 1,560
Hey guys,
My AVR is a Pioneer Elite VSX-94THX. I have a Polk PSW 150. I have switched the built in crossover in the AVR a couple times. I play Blu Ray music and movies alike.
Just wondering what you MHZ you guys put your AVR crossover setting.
I have LSI fronts and center if that helps you out.
Tony
Post edited by Vette C6.r on
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited November 2010
    Tony, I've flipped mine back and forth from 60 to 80 and noticed little, if any, difference. I stuck with the "standard" 80, just because. (This is for the 7.1 rig in my sig. For my Def Tech sats, I'm at 100.)
    What LSIs do you have? Towers, bookies?
  • Vette C6.r
    You forgot already Ed ??? lol
    I have the 15 towers..
    I realize that every system and room will react differently. Just trying to get a generally accepted setting.
  • samnor
    samnor Posts: 155
    thx recommendation is 80hz and that has worked out the best for me. I've tried 60hz and found that it introduces some really bad peaks in my setup (my fronts go down to 35hz easily) . Sometimes the avr isnt really exact on the crossover either so you may have to tweak that further. You'd obviously notice it much more in music than in movies... so if you listen more to to the former, I think 80hz is fine...
    Fronts: Wharfedale diamond 9.6
    Sub: Wharfedale sw250
    Rears: Wharfedale diamond 9.1
    Center: Paradigm cc-350
    Pre-amp: Oppo dv981hd
    Amp for fronts: Parasound hca-1500a
    Amp for rears: Adcom gfa-5400
    Amp for center: Marantz MA500 monoblock
    Polk multimedia speakers for PC setup
  • Vette C6.r
    Thanks for the info MD Audio and Samnor.
    I will try it at 80.
  • mdaudioguy
    Vette C6.r wrote: »
    Oh yeah, forgot about those. When you were talking HT, all I could think of was the RT12s(?) that you had upstairs. Sorry, but once I heard those SDAs... I forgot that you had LSis!
  • Vette C6.r
    LOL. They had a blown tweeter and the XO's weren't done.
    They have the XO's done, tweeter problem resolved and new gear.
    Let me know when you're in my area again if you want to stop by again.
    And you are correct. The RT12's were upstairs. I sold them though. Got RTA15's up there now.
  • MitchTX
    MitchTX Posts: 1
    Onkyo TX-SR804, Polk TSi200 Front R & L, Polk CS-20 center, Polk Subwoofer PSW-111 all firing forward and 4 Polk TC615 ceiling speakers firing down. I have all channels set at 80MHz. The subwoofer is dialed in at 80MHz to match the receiver's setting. The phase is set at 0. Should I make any changes? I'm not familiar with this process and normally set things things at default. Now I'm trying to get the best sound I can.
  • aboroth00
    aboroth00 Posts: 1,108
    edited December 2010
    MitchTX wrote: »
    You might want to try playing with the phase to get it to mix well with your mains. 80hz is fine as a XO but you can play with that setting to see what goes best.
    2Ch Tube Audio Convert
