Need 2 MW6511's
Fongolio
Fongolio Posts: 3,516
edited November 2010 in Wanted (WTB) Classifieds
I blew two on my right speaker today while changing a turntable out (don't ask). Long story short I need two MW6511's for my SDA-1C's. Can anyone help or does Polk Audio still have these? Thanks.
Kelvin
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Post edited by Fongolio on
  • bikerboy
    bikerboy Posts: 1,231
    I had to get a pair from Polk. $105 shipped to me in Seattle. They got here in 3 days. To the Great White North it will be more time and $:eek:
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
    Toolfan66 Posts: 18,065
    I wanna ask what happened it might tell someone what not to do..
    I unplug everything when changing things out..
  • restanim
    restanim Posts: 227
    Let me guess... He disconnected the RCA cables while everything was all powered up. You get a ground loop hum for a second or two, causing a strong signal to go to the speakers. Hence blown MW6511's :frown:
    polkaudio
    Currently Own:
    RTA-11T Light Oak, Aug/2011 to present
    SDA-CRS+ Aug/2011 to present
    RTA-11T Black, Dec/2013 to present
    Previously Owned:
    SDA-SRS 2.3 May/1990 to June/1991
    SRS 1.2TL June/1991 to May/1995
    SDA-1C Aug/2005 to Dec/2011
    SRS 1.2TL Sept/2009 to Sept/2015
  • Fongolio
    Turntable was taken out to swap with another. Pre-amp also swapped because of a ground loop hum. New pre amp in, didn't check volume knob. On full!!! Hit power button and something was not connected right and FFFRRRAAAAPPPP!!!!! Goodbye two 6511's!! Moral of story.....always always always check the frickin' volume knob before powering up.
    On a different but same note, I emailed Polk customer service and the tell me the 6510 is the correct and identical replacement for the 6511 but I thought the 6510's were the two outside dimensional drivers. Anyone know the answer? Thanks.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
    That don't make sense.. You need two MW6511's!!!
  • Fongolio
    Here's what Walter wrote:
    Kelvin;
    Sorry for the mistake the correct driver is the MW6510 not 6503. The MW6510 is the direct replacement for the 6511.
    Walter
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • gimpod
    gimpod Posts: 1,793
    Fongolio wrote: »
    Kelvin;
    Walter
    Sorry but that doesn't make sense. The MW6510 is an 8 Ohm driver and the MW6511 is 4 Ohms, You defiantly don't want to replace one with the other.
    I would CALL polk you'll most likely get a different answer and the right one.
  • falconcry72
    falconcry72 Posts: 3,580
    I believe 1C's use 6510's as the interior, stereo drivers, and 6511's as the exterior, dimensional drivers.
  • gimpod
    gimpod Posts: 1,793
    It's the other way around, 6511's are the interior stereo drivers and the 6510's as the exterior, dimensional drivers.
  • Fongolio
    Are the MW6503's similar in impedence and voice? Perhaps I could replace all four 6511's until I can find two more. Anyone?
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • Fongolio
    bump
    Still need the 6511's or an answer to the question "can the 6503's be used as a reasonable replacement for 6511's?".
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • Fongolio
    bump
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • falconcry72
    gimpod wrote: »
    You are correct. I was confused because my 2B's use the 6511 as the dimensional driver. Carry on....
  • zarrdoss
    zarrdoss Posts: 2,562
    Do you still need some 6511's? I have two newer ones I will sell you.
  • Fongolio
    zarrdoss wrote: »
    pm sent
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • Fongolio
    Many thanks to Zarrdoss for selling me a pair of these. Thanks to all who helped or made suggestions. I'll be a lot more carefull hooking up new equipment in the future.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • zarrdoss
    your welcome, I will get those out Monday. Now that they are not making anymore I guess we all better be careful.
  • Fongolio
    Kevin (zarrdoss) is the man!! The two 6511's arrived today and they were packed with care and survived both the US Postal system and Canada Post fully functional. I covered the baskets in dynamat like the previous ones and popped them back in to the cabinets. Fantastic!! My 1C's sing again just like they did the day I brought them home!! Gigantic thanks and a happy thanksgiving to Kevin and all of you at CP.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
