cleaning speakers
meg
meg Posts: 19
edited November 2010 in Vintage Speakers
Hi all, I have a pair od SDA SRS withe damaged grill covers, so they are left off. The cones are collecting dust and the rubber like rims around the cones are getting a brown like type of film/dirt. Any recomondations for cleaning these speakers and or conditioning them to look and last better?
Post edited by meg on
  • Vette C6.r
    Vette C6.r Posts: 1,560
    Use windex and a high quality paper towel that won't leave, paper towel white "dust".
    Spray the windex on the towel then wipe away.
  • vmaxer
    vmaxer Posts: 5,117
    Vette C6.r wrote: »
    Agreed, I use lintless cotton cloths.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • meg
    meg Posts: 19
    Thank you so much. I will try that. Is there anything I can do to the rubber like material around the speakers, they are dry and dirty. I tried water and towel, that didnt do anything. I'm afraid to use anything like armor all or some other type of luberication liquid. Could any of that damage?
  • phocion
    phocion Posts: 157
    Windex should work on those as well with some light rubbing, but I would steer clear of armor all, which would probably just attract more dust in the long run.
    The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche
  • jimmydep
    jimmydep Posts: 1,305
    You could move them to your back yard, borrow your neighbors 3500psi power washer and with a stiff wire brush give them a good cleaning,..............................or just use a little windex and a lint-free cloth.
    F1nut Posts: 50,761
    Windex will clean the cones and surrounds perfectly. Do NOT use Armor All.
