FXi A4 Positioning
PhoenixMage
PhoenixMage Posts: 5
edited November 2010 in Speakers
Hi,
I am setting up my first Home Theatre using an A7 pack. I am wondering when mounting the XFi A4's as rears should they be mounted slightly behind the seating or fairly square with the seating?
Regards,
Tony
Post edited by PhoenixMage on
  • dorokusai
    dorokusai Posts: 25,628
    Hi,
    Regards,
    Tony
    I would mount them directly behind the seating area, if possible and play with the dipole/bipole setting as you see fit for the best sound. If you can't mount them directly behind, then your idea of slightly behind the seating area would be my choice.
  • PhoenixMage
    Thanks for the reply, unfortunately its in my living not a dedicated room and my house is open plan so no rear wall.
    What about height? Should they be between head height the roof or closer to head height
  • dorokusai
    4-6" inches from the ceiling. Never head height if at all possible.
  • PhoenixMage
