Is Bi-wire for new speakers only?
Hi, just want to get some information about bi-wiring an old bose bookshelf speakers? How can I know if a speaker is capable of such a sophisticated set up.
Also, do I need to have an amp to bi-wire my speakers or can I use my pre-amp receivers?
Thank you for your kind response
HT:
DENON AVR-3803
DENON DVM-1805
SONY DVP-NS300
SONY 36' HDTV Wega
ADCOM GFA-555
ADCOM GFA-555
ADCOM GFA-2535
ADCOM ACE-515
POLK RTi70's (Bi-Amped)
POLK CSi40
POLK FXi30's
POLK RTi38's
POLK CSi20
POLK PSW 450
SVS PB2 Plus
2 CH Stereo:
AudioSource Pre/Amp 1
Hafler DH-500
Sony CDP-CX235
Monster Cable HTS3500
SDA SRS 2.3tl
DENON AVR-3803
DENON DVM-1805
SONY DVP-NS300
SONY 36' HDTV Wega
ADCOM GFA-555
ADCOM GFA-555
ADCOM GFA-2535
ADCOM ACE-515
POLK CSi40
POLK FXi30's
POLK RTi38's
POLK CSi20
POLK PSW 450
SVS PB2 Plus
2 CH Stereo:
Hafler DH-500
Sony CDP-CX235
SDA SRS 2.3tl
Post edited by TheMaster on
Bi-Wire requires 2 sets of speaker terminals. (On the speaker) and binding post on the receiver
To bi-wire on a receiver, you would mainly need binding post terminals, unless you can tell me a way your going to shove 2 sets of speaker wire in that small hole. You mainly can run 2 sets of wire, one to the top post, one to the bottum post, and then do one set at one end with banana plugs - and put it straight into the terminal, and then stick bare wire into the slot in the terminal. That is the cheap way, or you could buy a bi-wire cable which isnt cheap. You can also BI-AMP, which requires 2 amps, you run one set of wires to one amp, and another set of wires to another amp. You can use a 2 channel amp to bi-amp one speaker I suppose.
Biwire/amp is not only for new speakers, many old speakers like the SDA SRS 1.2tl's and such if im not mistaken had this feature.
Bose...bleh....why do you own bose?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
this may put it into "picture" === WRONG BAD PIC! FORGET IT! LOL!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Actually, don't wire it up like that picture...the picture is wrong...
The white should go to both reds, and the black should go to both black...
I don't recommend hooking it up like the picture illustrates...
-BLTWFTPQ
Receiver: Outlaw 1050
Amps: Outlaw M-200 x 3 (Powering Mains and Center)
Mains: RT800i; Center: CS400i; Surrounds: F/X500i
Sub1: 214L Vented Tempest
Sub2: 122L Sealed Tempest -
dido with BeginnersLuck, picture is wrong. White with both reds and black with both blacks.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
here is a bi-wire hook up...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
and the receiver side, notice the colors, blacks twisted together, reds twisted together, substitute the colors for what ever color your wire is......MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Nice. That's much better.SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
-BL
WEEEEEEEE! TRULY SORRY BOUT DAT GUYS! lol! Didnt realize that! VERY SORRY AGAIN!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
