Routing amp power wire
mdaudioguy
mdaudioguy Posts: 5,165
edited November 2010 in Car Audio & Electronics
'09 Eclipse - I'm planning to run a 4 gauge power wire from the hatch to the battery. Any suggestions? I looked for an obvious opening/grommet in the firewall and none jumped out at me. (You know, with a "Run power wire through here!" label on it. :wink:)
Post edited by mdaudioguy on
  • mdaudioguy
    It's on the drivers side, but it's crowded over there. I may try pulling the glove box and check back there.
  • MacLeod
    MacLeod Posts: 14,358
    There is almost always an opening in the firewall thatll lead into the cabin. Id check from both sides very close. You may have to piggy back thru another opening. On my Edge, there was a couple wires running thru this big rubber sleeve and into the engine compartment. I poked a hole in it and snaked the power wire thru and into the engine compartment. Worked like a charm.
    In my Accord, there was an opening that had a grommet installed but nothing going thru so I popped it out and ran on thru.
    My beloved Dodge Ram was like the Edge. No lone opening so I piggy backed thru an opening used by some other wires.
  • PerfectCreature
    PerfectCreature Posts: 1,456
    My Grand Am had a grommet sort of under the steering column that I used, ran through like a dream....try there?
    Always follow the wires.
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
