EQ's w/SDA?
brgman
brgman Posts: 2,859
edited November 2010 in Vintage Speakers
Does anyone use equalizers with their SDA's? Does anyone use an equalizer at all anymore? I have an ole Phase Linear 1400 II and wonder if there is any use for it any longer.
I’M OFFENDED!!!!
Post edited by brgman on
  • george daniel
    george daniel Posts: 12,096
    I suppose you can try it and see if you prefer it.Me,, I just play mine through a sinple 2channel system,,I have found (for me),the most direct simple approach works best,YMMV,, good luck.:smile:
  • Hamatym
    Hamatym Posts: 269
    Both my Dad and I use the larger DBX EQ's with our main 2-channel systems.....AWESOME! A lot of the guys here do not like it, which is fine.....The SDA's take quite well to the EQ's and can be dialed in to your personal preference very easily.
    Just my $.02
  • dorokusai
    dorokusai Posts: 25,577
    EQ's have their place but it's usually because of a problem elsewhere, whether it be the room or the ears.
    heiney9 Posts: 25,217
    Nope, drop it off at the local Goodwill
  • inspiredsports
    inspiredsports Posts: 5,501
    Hi brg,
    I've found by lots of experimentation that the equalizer will eventually find it's way out of the loop as you take care of each and every detail.
    As I replaced/rebuilt power, power cables, IC's, speaker cables, sources, preamps and amps, I found the equalizer eventually dialed in on zeros. Once that happened, even more noise was gone with it completely removed from the loop. Only good sound remained.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • brgman
    brgman Posts: 2,859
    Thanks for the feedback.Figured it wouldnt play well.I'm glad i asked before i cleaned this thing up and went to the trouble of hooking it up.
    I’M OFFENDED!!!!
    treitz3 Posts: 19,220
    Hi brg,
    Nice post. :wink:
    The only other thing I could possibly add to this would be that once the EQ was out of the rig, the issues I had [but just couldn't shake] with the precision of the sound stage all but disappeared.
  • ben62670
    ben62670 Posts: 15,969
    Good cables and synergy go a long way. I used to like EQ's, but they are more crap in the signal path.
    Ben
  • Fongolio
    Fongolio Posts: 3,516
    I still use an ADC Soundshaper 3 Paraequalizer mainly because my room has problems that I can't afford to correct right now. It really helps and is actually very quiet. It's one of the best fully analog eq's made back in the day.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • zarrdoss
    zarrdoss Posts: 2,562
    Fongolio wrote: »
    I use them as well for the same reasons. Just clean it up and try it, only way to be sure IMO.
