To Dampen or not to Dampen
Ricardo
I am installing the rings in mt RTA 15 TL's; also Dynamating the PR and MW baskets.
While having the cabinets empty (removed drivers and stuffing), if I knock on the walls it sounds hollow and resonant.
Would dampening the inside walls help or hurt the sound? I've read somewhere that vented designs benefit from dampening, but sealed design benefit from stuffing. These have their stuff...
Any thoughts?
Any thoughts?
SOPA
SOPA
I know some Polkies have had good success with the Sonic Barrier type products.
The material features our exclusive embossed surface finish that helps to trap acoustic energy and improve high frequency performance. This finish is applied to an acoustic-grade open-cell polyether foam, which absorbs and converts the acoustic energy into low-level heat. A very aggressive pressure sensitive adhesive provides easy and permanent installation onto any surface. The Sonic Barrier 1/2" foam is excellent for use in small loudspeaker projects, where bulky damping materials are not feasible. The foam will help absorb unwanted sound from within the cabinet without disrupting airflow between the driver and port. This can reduce unwanted sound reflections and prevent them from exiting through the cone or port. In small enclosures, the foam can add a valuable increase in apparent volume, which can help to offset the space taken up by the driver itself or the port.
Thanks Jake. I see it specifically talks about the benefits for ported speakers. I want to know if it adds anything for sealed speakers._________________________________________________
Larry found that it helped his 1C's and made his 1.2TL's sound worse.
Ok. I'll leave them alone. There's enough stuffing in there._________________________________________________
A couple pieces of Black Hole or Sonic Barrier....not the entire interior.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I found putting No Rez in my cabinet helped alot with my speakers. But I did not cover everything like Larry did...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks guys. I'm going to leave it alone for now. There's really a lot of that white stuff in there. Three "sheets" that cover back and side walls. Only the bottom section where the two PR's are is left open. I know that if I add something else I will be wondering if I added too much, if I should've removed some of the white stuff......
Also leaving it alone might give me a reason for a new project down the road._________________________________________________
