Tube amp with these speakers?
Pycroft
Pycroft Posts: 1,961
edited November 2010 in Speakers
Hi all -
Something came up locally and I am looking for feedback. I know power isn't everything, especially with tubes. Wright Audio Mono 8's came up locally. They are, I believe, 8 watts per channel. I am currently using a Dynaco ST-70 which is more. Now...my speakers aren't known for being particularly efficient - the Sony SS-M7s. Sensitivity is 85db I believe. I am curious what people think of the pairing. I know Wright is a great name in the tube amp industry. I read some online about them, and didn't understand it all. Any comments would be helpful! Thanks, and goodnight.
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
  • vc69
    vc69 Posts: 2,500
    That Dynaco is a sweet piece. The Wrights would be better paired with a more efficient speaker.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • zingo
    zingo Posts: 11,258
    A demo is obviously the best way to go with questionable component matching, but 300B amps usually aren't enough for 85db speakers; especially depending on how you listen to them.
    heiney9 Posts: 25,612
    I doubt very much you'll be happy using an 8wpc amp with 85dB speakers. I have a pair of 87dB speakers which are small bookies and neither of my tube amps drive them with any authority or volume. Amp number 1 is 15 wpc hybrid tube amp. Amp 2 is a 12 wpc push/pull 6V6 based amp and Amp 3 is an EL 34 based single ended pentode. All 3 run my 5B's at 91dB efficiency with authority just not a huge amount of volume and this is in a smaller 2nd bedroom I use as an office.
    I'd pass if you were going to use those solely with the Sony speakers
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I would get it because then I could get some more speakers to use with it.
    Tubes Rule.
    RT1
    Tubes Rule.
    RT1
    I was going to suggest that too! An inexpensive pair of modded 5B's would blow your socks off.
  • TroyD
    TroyD Posts: 13,124
    With your current speaks, no go.
    That said though, with the right speakers.....that could be a very cool thing.
    BDT
  • Pycroft
    The speakers aren't going anywhere, and I don't have the dough to fork over for a second system...thanks for the advice!
    James
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
