SDA SRS 1.2tl
davis419b
davis419b Posts: 61
edited November 2010 in Vintage Speakers
I am fixing to buy some monoblock tube amps and I am wondering how much power each would need to have to make them sing ?
Post edited by davis419b on
  • inspiredsports
    inspiredsports Posts: 5,501
    Just curious, are monoblocks the best answer for sound quality with your SDA's?
    What is the conventional wisdom concerning SDA's and monoblocks with an original (or custom) AI-1 interconnect, or using a great high-power 2-channel amp?
    I guess I'm ignoring the possibility that some monoblocks can be strapped, but then doesn't that defeat part of the reason for having discrete monoblocks?
    If I had unlimited funds, I'd probably opt for a big Pass, Krell, McIntosh, VTL, Musical Fidelity, etc. stereo amp, but monoblocks sure do look cooler :smile:
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • davis419b
    davis419b Posts: 61
    Lasareath wrote: »
    at least 200 watts each, the more the better
    Im not talking SS power Im talking tube power !
    nooshinjohn Posts: 25,421
    davis419b wrote: »
    There are a few tubes that can easily reach 200wpc or better.
  • davis419b
    davis419b Posts: 61
    And how expensive are those going to be ?
    EndersShadow Posts: 17,590
    Carver Statments perhaps ;)...sorry your tube amps just come to mind when I hear tube lol...
    F1nut Posts: 50,569
    davis419b wrote: »
    Around 100 wpc should do very nicely. You do not need 200 wpc of tube power.
  • davis419b
    davis419b Posts: 61
    Thats what I was thinking. The amps I am buying are 140wpc and I was hoping that would be enough.
    Thanks, F1nut
    It's ok...
    davis419b wrote: »
    It depends actually... My set will end up at around $3,500, but I am doing the work myself. I would recommend going with a Rogue Audio Zeus two channel amp rather than monoblocks however...
    http://cgis.audiogon.com/cgi-bin/srch_fs.pl?searchstring=rogue
  • toucanet
    toucanet Posts: 580
    Warning - The Zeus weighs 200 lbs. Call an enemy to help you move that monster!
    F1nut Posts: 50,569
    davis419b wrote: »
    Thanks, F1nut
    Very good, sir. Remember, you will need to use the AI-1 cable when running mono blocks.
