Amplifer........Help
2fast
I don't know which amplifer is good for 100-2,000 watts.Tell me please.
Post edited by 2fast on
We're gonna need more info than that bud... what's your price range... What are you hooking up to it... MAKE SURE TO TELL US THE OHM LOAD YOU ARE RUNNING... the RMS power of whatever you want to run off of it... any other info that you think might help too...
Keep in mind that the higher the RMS power and quality of an amp the more you're going to need to spend on high quality wires, caps, etc...Hemi: (HEM -e) adj. Mopar in type, V8, hot tempered, native to the United States, carnivorous, eats primarily Mustangs, Camaros, and Corvettes. Also enjoys smoking a good import now and then to relax. -
$100-$1,000
Rockfard
we can only help you out if you tell us what speakers youre running and what theyre rms rating is
-Cody -
10" HE rockford subwooferns Watts they have 50-200 Hz 32-200
Rockford Fosgate 351M
run you about $300The Artist formerly known as PoweredByDodge -
They are $250.00
I'm losing my touch, I really should have picked up on that link before I actually clicked on it."The Big C"
-Cody -
Thanks guys
www.Hop is hooked on phonics okay a know that
