Speaker selection help
SoulBrother
SoulBrother Posts: 3
edited November 2010 in Speakers
I'm a music listener and a movie watcher so I want a decent system that will allow me to enjoy both.
My current setup consists of:
Onkyo TX-SR601 receiver
Polk m60's from my fronts
Polk CS2 center
and I'm using the bookshelf surrounds and sub from my Onkyo SKS-HT500 speaker kit
I know this isn't an ideal setup but I'm in an apartment and on a budget (space and money concerns). Someone had suggested I get m40s for my surround but they look rather large for a bookshelf and frankly I don't know how much better they are than what I already have. Can anyone take a peek at the specs of my Onkyo speakers and tell me for certain that inexpensive Polks are going to give me a huge difference in audio quality and clarity?
Speaker recommendations would be nice. I think I'm fine with my current sub as I get some decent base that shakes my floor as it is. Any more and I'd have some very irate neighbors.
Post edited by SoulBrother on
  • falconcry72
    falconcry72 Posts: 3,580
    Welcome to Club Polk!:smile: There is a wealth of info here.
    Specs for your Onkyo surrounds:
    Type 2-Way, Bass Reflex
    Woofer 4"" Cone
    Tweeter 1"" Balanced-Dome
    Frequency Response 65 Hz-35 kHz
    Sensitivity 82 dB/W/m
    Max. Power 70 W
    Nominal Impedance 8 ohm
    Dimensions (W x H x D) 6 1/2"" x 8 7/16"" x 8 7/16""
    Weight 4.5 lbs./2.1 kg
    Specs for the Polk Audio M40's:
    Driver Units Tweeter Complement: one 1" cloth dome
    Driver Complement: two 5.25" Bi-Laminate driver
    Power Rating 20-125W
    Frequency Response 47Hz-25kHz
    Nominal Impedance 8 Ohm
    Sensitivity 89db
    Connectors Inputs: Dual (bi-amp) 5 way binding posts
    Specs for thw Polk Audio M30's:
    Driver Complement: one 5.25" Bi-Laminate driver
    Power Rating 20-100W
    Frequency Response 55Hz-25kHz
    Sensitivity 89db
    It's amazing what a little Google'ing can do...:rolleyes:
    Both sets of Polks will have better base than your Onkyos, but more importantly, they'll be timbre-matched to the rest of your system. I say go for them. The M30's are smaller than the M40's if you're worried about size.
    Good luck!
  • SoulBrother
    Thank Falcon. While I'm able to Google for the specs I'm really illiterate when it comes to what they mean. That is why I was asking for assistance. For example I'm reading the ranges for the 30's and 40's and it looks to me as if the 30's have a wider range. Is that better? The Onkyo's have a higher upper register but less bass, is that right? Would that be an advantage in some situations?
    I want to know what speakers would be suggested to match my fronts and center. They don't have to be 30's or 40's. Just looking for great sound at a good price. I don't think I could spend more than $300 right now but welcome different opinions.
  • falconcry72
    The 30's and 40's are the only bookeshelves that will be a perfect match to your front and center. The 40's are better, but bigger.
    As far as frequency response goes, humans can't really hear above 20khz, or below 20hz, so anything above that is moot. The 40's have a wider range, as they drop to 47hz whereas the 30's only drop to 55hz.
    Newegg has the 40's for $180 shipped for a black pair ($200 shipped for a cherry pair):
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290202
    The 30's are $150 shipped for either black or cherry:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290200
    I'd spend the extra $30 and get the 40's, if you have the space.
    Let us know what you end up with and how they sound!:smile:
  • SoulBrother
    One more question Falcon. I was reading some people do the Polk floorstanding models for sides and rear. This might be easier for my particular layout than bookshelf speakers that are this big. Do you know what model those might be and how those work/sound compared to 30's/40's?
  • mole'
    mole' Posts: 3,160
    sent you a PM. i have a set of Monitor 50/40 im not using anymore.
    mole'
  • falconcry72
    M50's, M60's, and M70's in order from smallest to biggest (best).
    If you wanted to go towers in the back, then the best upgrade would be to move your 60's to the rear, and buy a pair of 70's for the front. Newegg has a promo right now for the 70's at $250 each, shipped, so total $500. That would be the most expensive, and best sounding:smile:, way to do towers all around.
    The cheapest way would be to leave your 60's up front and get a set of 50's for rears. That'll run $260.
    The rear channels don't get a whole lot of info, and generally don't get much bass, so it may be overkill. That being said, upgrading your fronts to 70's will make the biggest impact on your system, as you'd be upgrading your fronts, which get a ton of info, AND your surrounds.
    How do you listen to music? Most people do 2-channel. If that's the case, then only upgrading your surrounds won't have any impact on your music listening experience, but upgrading the fronts to 70's will.
  • falconcry72
    mole' wrote: »
    There ya go, you could get mole's 50's and 40's and run a 7.1!
  • dcmartinpc
    dcmartinpc Posts: 844
    Actually, Newegg has the Monitor 70 Cherries for around $330 shipped for the pair with promo code SPEAKER112B. But that code expires today. The Blacks are just a little more expensive, around $350 shipped for the pair with promo code EMCZZYN63. That ends 11/8. Worth a look, both of those deals are AWESOME! If I needed another set of Monitor 70's, I would be all over these.
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • dcmartinpc
  • angelsfann02
    angelsfann02 Posts: 589
    dc martinpc- You got me looking at those for my bedroom set-up!
    LIVING ROOM:
    Pioneer PDP-6070HD, Pioneer Elite SC-25, Pioneer Elite BDP-05FD,
    Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning
    BEDROOM: VIZIO 32" LCD, Pioneer Elite VSX-23txh, Pioneer Elite BDP-23FD, Parasound HCA-2205A, Mirage Nanosat Prestige Speakers 5.1, Mirage S8 Sub, Monoprice cables, APC Surge Protection.
  • dcmartinpc
    I use them in my living room on my main level for music listening and I love them. They aren't my LSi9's, but for music listening without a sub, they are phenomenal! I don't have a TV or anything in my living room anymore, 2 channel only for this system. That is a great deal on a great set of speakers.
    Don
