RTi A7's - What kind of plugs work, bannana or others?
:biggrin:FUNNY GUY:biggrin:
I think i'll end up getting them, everybody seems to like them, d oyou notice the bluejeans is now sodering bananas to their wire very that extra tight fit, and in a none heat traditional way. I'm leaning toward their beldon wire...but was considering AQ for cables for the Amp I want to get:cool:
Any thoughts on amps (emo, parasound,poss sunfire if not too expensive, etc...)and moderately priced cables without sacrificing quality? Trying to spend around 700(ish on the amp) and looking for 5 channel 200w/chBonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon) -
Here's an Adcom 150 x 5 for $700 on audiogon
Here's an Outlaw 200 x 5 for $899 on videogon
Here's a Parasound 250 x 5 on eBay
That's what I could find from a cursory search in your range. Maybe you can get a good 2 or 3 channel amp now and add a 2 or 3 later? These things aren't cheap
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Thanks Praz,
I did happen to notice that they're not too cheap and the only problem i thought of was if i buy a 3 channel one now and add a 2 channel later then the 2 channels seem to only be 125w or 150w, but i want a 200w per channel amp, i know the receiver can help but really, by how much? I was hoping for 200w per channel across the board. Am i thinking wrong? Can the surrounds not handle or not need the 200w? I was going to get the FXi A4 or 6's soon. I looked at the emo 5chx200w. any thoughts on amps given wha i said?Bonus Room:
RTi A7's / CSi A6
DSW PRO 600 sub
Samsung BD-C5500
Living Room:
Samsung 58" PLasma
