surroundbar 42
sda2mike
sda2mike Posts: 3,131
edited November 2010 in The Clubhouse
whats a realistic price range for one of these...used?
thanks
mike
Post edited by sda2mike on
  • TECHNOKID
    TECHNOKID Posts: 4,298
    sda2mike wrote: »
    thanks
    mike
    The surroundbar 42'' goes for 600$ on Polk site. Keep in mind this products dates a few years and there are multiple choice now available which also brings the price down.
    If you look at the Polk ebay store http://stores.ebay.com/Polk-Audio-Direct/_i.html?_nkw=surroundbar&submit=Search&_sid=686154689 it should give you a pretty good idea. Also keep in mind you get 2 years warranty on Polk refurbished.
    Your choice would be;
    * Maybe 150 - 200$ max on a use?
    * Why don't you buy refurbish from Polk at 300$ or...
    * Perhaps put a bid on one of them?
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
