repair techs help needed
scottyboy76
we have a procinema td 5000 that went ffft
from pics is it worth fixing or even doable?
a kid at the grocery store does work for free so its just a matter of is it doable.
thanks
thanks
humpty dumpty was pushed
Post edited by scottyboy76 on
Is it fixable? Yes! At least, what you showed in the pictures is fixable.
But does it worth fixing?
All depends. May be it's worth it if what you shown in the pictures is the only problem. But I highly doubt it. What you have in the picture is only part of the unit and there may be something more down the line that you need to look at.
How did it happen? It depends a lot on how it's happened and how much you are willing to put into it for parts even if there is someone fixing it for free.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
yeah
it can be fixed. -
If the kid works for free grt him to provide you an estimate of the repair before he actually fixes it and from there make your decision. Looks like there is quite a few things fried on that board so doable? Maybe maybe not....scottyboy76 wrote: »we have a procinema td 5000 that went ffft
thanksDARE TO SOAR:
