Monitor 30 Crossover
At the moment I have four fronts. Two M60s and two M30s.
I have played around a bit with the crossover and 60Hz sounds cleanest to me.
Since my speakers are run in A+B, both fronts use the same settings.
Would I damage my M30s if they were set to crossover at 60Hz?
Post edited by Solidate on
You won't hurt anything doing that. Just consider the fact that you can run M-30s off an integrated amp or a stereo receiver that has NO crossover point as FULL RANGE speakers. All that happens is that the deep bass gets rolled off after about 55hz...the real limit on these speakers is 63 Hz so it's pretty close to the crossover. The bass might be a little cleaner if you crossed over a little higher than 63, though?
But you're OK!.
