Sound Bar 3000 connectivity problem. Please help.
escaudio
escaudio Posts: 2
Got a sound bar last night for the guest bedroom and cannot get it to work? I plugged it in, plugged in the sub and connected the optical cable from the tv to the sound bar, but nothing? In the guest bedroom there is a Sharp Aquos and a PS3 using an HDMI cable. The speaker has power and is making a static sound when turned up but nothing else in any of the "source" modes 1-3. Please help a noob out. Thanks!
  • nguyendot
    nguyendot Posts: 3,595
    edited October 2010
    Have you turned the optical output on for your tv?
    Main Surround -
  • escaudio
    escaudio Posts: 2
    edited October 2010
    No, how do I do that?
  • nguyendot
    edited October 2010
    Check the manual for your tv....
    Main Surround -
