voltage meters...
PoweredByDodge
does anybody make a small (say maybe 2 1/2 inch diameter or smaller) voltage gauge that is just a simple two wire hookup - bat and ground ???
there is only a dummy light on the dash and i'd like to get some sort of a voltage gauge to even go in the glove box or something just so i could occasionally take a peek if something seemed odd while driving.
The Artist formerly known as PoweredByDodge
Post edited by PoweredByDodge on
Check out Summit Racing or JEG'S High Performance. They both carry a slew of guages and should be able to help you find something you are looking for.Expert Moron Extraordinaire
Autometer makes a variety of 2 1/8 inch voltage gauges that are two wire hook up. They also have illumination wires, but those aren't required for operation.Autometer
josh,
i was checkin out the autometer site, and the 1 1/2 inch analog voltmeter (item 2356) looks like it would suit me pretty well... is 20 bucks about right for something like that -- only saw a couple places online and they all say about 20 bones... that seem straight for somethin like that or should i keep diggin?The Artist formerly known as PoweredByDodge -
i saw one at radio shack today for $25...2x4x.75ish
you flip it open
-Cody -
cody --- digital or analog??The Artist formerly known as PoweredByDodge
![[Deleted User]](https://forum.polkaudio.com/applications/dashboard/design/images/banned.png)
