To split or not to, that is the question?
myke
myke Posts: 138
I have read a lot of opinions on various site so I would like to pose it here. With an A/V that only has one sub out, can I split it and add another sub to fill my large room? I would like more bass than I have and it feels lacking in the far corners of the living room. It's an open room with the rest of the downstairs and measures, guessing cause I'm not at home right now, 15+' x 20+' x 10' height. Am I gonna lose signal or frequency?
Bonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon)
Post edited by myke on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2010
    Yes you can split it with no problem.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • myke
    myke Posts: 138
    edited October 2010
    thanks disneyjoe,
    so no loss in frequency, no loss in signal, no mixmatched responce? I was told since i'm splitting the signal then is would have repercussions, like some of the ones mentioned in the earlier sentence or others my novice mind is unaware of.
    what if I combine a larger sub say 500w with a smaller one around 300-400w just to fill the back in with some bass, an I going to notice the difference?
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • pearsall001
    pearsall001 Posts: 5,358
    edited October 2010
    If possible try to stay with the same sub for best results. Splitting the signal has no adverse effect what so ever.
  • Face
    Face Posts: 14,340
    edited October 2010
    If you use separate electrical lines, you may cause a ground loop.
  • myke
    myke Posts: 138
    edited October 2010
    They would probably be on the same circuit....and i hate to sound stupid but whats a ground loop and does it have adverse actions?
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • disneyjoe7
    edited October 2010
    Ground loop is when you get a hum 60hz noise. The loop is given the input of an amp some current where the hum 60hz is amp to a speaker. There's ways to fix that issue, not too worry. Go Forward.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    txcoastal1 Posts: 13,519
    edited October 2010
    Is it the same thing when you turned on the hair dryer and the TV got static?
    Tony M Posts: 11,829
    edited October 2010
    I have two subs split from 1 output wire now. I've done it in the past to. A sub on each side of the couch does wonders. LOL...I'm lovin it now. 4 subs up front and 2 beside the couch. Yes we vibrate with impacts.
  • djperez81
    djperez81 Posts: 388
    edited October 2010
    Damn tony a lil much dont you think:biggrin:... it probably sounds awesome though
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
