Sound quality having speakers with a higher impedance than the amp
Feferefe
Feferefe Posts: 10
edited October 2010 in Speakers
Hi:
I want to know if the sound quality is affected if I connect a set of speakers with a higher impedance than the amp. I have a pair of Polk RTi10 (8 ohms) and planning to buy a Pioneer M10X ($200.00) that is 4 ohms to Bi-Amp the lows of the RTi10's. If someone have a better Amplifier (8 ohms) for $200 let me know.
Thanks,
Post edited by Feferefe on
  • TNRabbit
    TNRabbit Posts: 2,168
    edited October 2010
    It doesn't quite work that way; Pioneer lists it like this on their site:
    100 Watts Per Channel (Stereo): 4 ohms from 20-20,000 Hz with no more than .3% Total Harmonic Distortion
    An amplifier can be rated by it's output into a given impedance (16 ohms, 8 ohms, 4 ohms, 2 ohms, 1 ohm). MOST are not able to produce into a 2 ohm load, and many inexpensive amps aren't stable into a constant 4 ohm load. Pioneer probably listed it this way as it is more impressive to say 100 watts into 4 ohms than what it will do into 8 ohms, probably along the line of 60 watts at best. It's safe into anything higher than 4 ohms, but just won't put out the same power at higher impedances, dropping as the impedance goes up.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
